Need help with timing!
Old Aug 23, 2004 | 01:09 AM
Awsum77's Avatar
Awsum77
Talking Need help with timing!
I have a '77 351-M. I run 85.5 octane through it. I was told with such a low octane fuel that I should set my timing to 6 degrees BTDC to get efficient power and gas mileage out of my engine. The factory settings on the valve cover calls for 12 degrees and I have it at 14...Is this wrong? What should I do? Any suggestions would be great.
Old Aug 23, 2004 | 08:28 AM
fmc400's Avatar
fmc400
MSEE
I would set your timing at 12 like the sticker says. The sticker is correct for any emmissions devices you may have or any other calibrations for your particular engine. If you get pinging, I would try stepping up your octane first.
Old Nov 12, 2004 | 09:17 AM
damoperator's Avatar
damoperator
The higher the advance the more power up to a point. With the proper timing, plugs and proper settings so that you don't explode the engine then try higher octane fuel.
ymeski56
41
Aug 13, 2011 04:55 PM
david00f150
Jun 28, 2009 08:11 PM
Rxman
2004 - 2008 F150
22
Jul 13, 2006 09:32 AM
RDavis - OKlahoma
2004 - 2008 F150
Apr 17, 2006 05:27 PM
ford_prof
Computer Chips & Tuners
Sep 15, 2003 07:45 AM
