Timing spout
Old Jul 15, 2002 | 01:16 PM
timberbuck's Avatar
timberbuck
Timing spout
[updated:LAST EDITED ON 15-Jul-02 AT 02:17 PM (EST)]I have read that the timing is 10 degrees BTDC with the timing spout removed. What/where is this? Is it a wire that goes to the coil or distributor?? Which one??? The last time I set the timing on a car, it was with a vacuum advance and points that I set with a dwell meter. I know I'm old, thank you.
Anything wrong with 11 or 12 degrees if it doesn't knock?
89 F-150 4WD 351w C6auto
Old Jul 15, 2002 | 08:30 PM
ftrain's Avatar
ftrain
Timing spout
Check near the distributor...its essentially just a plug to jumper the wires together...When you remove the plug, the computer will stop adjusting timing and allow you to set base timing...
Hard to describe, but it shoud be a small black connector plugged into a harness around there....(if you have distributor mounted control module, my spout comes out of that same harness...)
Ronnie
1987 F150 Reg Cab, 302MFI, AOD, 3.55 Rear, K&N Filter
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=4972&.jpg
Old Jul 16, 2002 | 01:10 PM
lghtningstruk's Avatar
lghtningstruk
Timing spout
On my 1994 5.8L it is just underneath the EEC-IV test plug on the inside of the drivers side fender. It is a wire harness with a black or grey plastic plug(kinda square shaped) snapped into it. Remove this plug to check the timing. That much timing is no problem if it doesn't knock - if it does I would try using a gasoline with more octane before turning the timing back down (just my 2 cents worth).
Old Jul 24, 2002 | 04:42 AM
kmichaelb's Avatar
kmichaelb
Timing spout
It's right below the distributor on my 90 F250 4X4 with 351w --
Old Jul 24, 2002 | 07:47 AM
cwmerc88's Avatar
cwmerc88
Timing spout
tonkyman
57
May 19, 2021 12:26 PM
sam03rc
Jul 9, 2013 06:09 PM
MattP51
Jun 29, 2011 09:03 PM
moondogg
Dec 22, 2004 11:13 AM
Boldt
19
Jan 8, 2003 11:51 AM
