Regeneration. How often?
Old Dec 9, 2010 | 09:03 PM
ruschejj's Avatar
ruschejj
I tow and drive interstates almost all the time. I had a 6.4 and it would regen 3 to 4 times per fuel tank which consumed a lot of fuel. This 6.7 is totally different. Depending on how you use the truck. I typically drive 1,000 or more miles between active regen cycles. Running the motor all day under load just makes it passive regen for significant amounts of time, so the fuel consumption of active regens is improved by something like 800% if I try to figure the impact on my fuel usage during exhaust cleaning events.
I don't pay attention to it though, the only thing that I can tell during an active regen is that familiar smell of the exhaust. The performance of the motor is virtually un effected.
Old Dec 10, 2010 | 08:03 PM
goldfish00's Avatar
goldfish00
Ok. What I have been monitoring is the active regen. Every time it shows up on the screen in the gauge cluster "cleaning exhaust filter". I'm assuming that the truck doesn't tell you every time the DEF is injected, this is the passive part that helps reduce active regen? Then the active regen is like the 6.4's and just shoots raw diesel fuel into the DPF?
Old Dec 10, 2010 | 11:47 PM
kper05's Avatar
kper05
No, there is no notification when DEF is injected into the exhaust stream because it happens all of the time when the engine is warm and producing NOx (or at least anytime when the engine isn't ice cold).
My understanding is DEF has nothing to do with regeneration.
Read this post by Crazy001:
https://www.ford-trucks.com/forums/9...ml#post8812716
https://www.ford-trucks.com/forums/9...ml#post8812913
Painted Horse also made a comment on this topic awhile back but I can't find his exact post.
Old Dec 11, 2010 | 07:30 PM
goldfish00's Avatar
goldfish00
Thanks for all your help guys. Much better understanding now.
nxtdiesel
Jun 11, 2022 06:47 PM
Slavoise
Jul 14, 2017 07:57 PM
BLUENGRAY05FX4
Jun 19, 2017 08:24 AM
mojavearcher
Mar 21, 2017 08:17 PM
doane00
6.7L Power Stroke Diesel
84
Jun 3, 2016 08:32 PM
