mpg input wanted
Old Apr 24, 2010 | 10:04 AM
  #31
Jakebrake's Avatar
Jakebrake
< Samantha...my Co-Pilot
Originally Posted by EpicCowlick
My dad installed one on my old Toyota when I was in high school and taught me how to use it. When I pressed down on the accelerator, the vacuum on the engine would increase and the gauge showed it. I learned how to "feather" the gas pedal to significantly improve my mpgs on that old import.
Not to nitpick here...but as you depressed the accelerator the manifold vacumm should have decreased...if the guage was reading vacumm it would read less vacumm as you got into the throttle more. Just wanted to clear that up. Manifold guages were great to monitor demand on the engine...and thereby improve economy.
Old Apr 24, 2010 | 10:14 AM
  #32
Jakebrake's Avatar
Jakebrake
Originally Posted by senix
emissions will never allow 20's again is my belief. I think upper teens is being pretty optimistic as well.
I think our Diesel Trucks are going through a stage similar to what gasoline engines did back in the 70's and 80's, when increased emissions caused many reiability/driveability concerns and poor fuel economy. Look at the economy and power gasoline engines are capable of now. I think as technology marches on that diesel engines will improve both in power and economy...I think 20's are well within reach. These engines will have much more complicated systems ( we won't want to work on them...at least most of us) and I think aftermarket tuners will have a tough time improving on them. Time will tell.
Old Apr 24, 2010 | 12:35 PM
  #33
EpicCowlick's Avatar
EpicCowlick
Yeah, you're probably right. I just learned to pay attention to the direction the gauge moved. To the right = bad, to the left = good.
Old Apr 25, 2010 | 11:17 AM
  #34
F350-6's Avatar
F350-6
Subscribing to hear more real world MPG numbers. I'd also like to hear how long a tank of urea actually lasts.
Old Apr 25, 2010 | 11:24 AM
  #35
radzer0's Avatar
radzer0
"Cleaning exhaust filter" came up on me like 5x yesterday. Seems like the more milage i get the quicker its cleaning the filter.
I know on another post somebody asked me about what type of cleaning its doing. It doesnt say if its active or not. Or whatever the term was. Just says its doing it.
Old Apr 25, 2010 | 12:20 PM
  #36
senix's Avatar
senix
then it would be active...passive you will not see.
Old Apr 25, 2010 | 12:24 PM
  #37
radzer0's Avatar
radzer0
I wonder how much DEF it uses when it does that. Cuz that sounds like im gonna run out alot quicker being its been doing it about every 10 miles.
Old Apr 25, 2010 | 12:31 PM
  #38
Tom's Avatar
Tom
That process uses no DEF whatsoever.
The two systems are completely separate. The DPF filters soot and particulate matter from your exhaust. The DEF is used in a catalytic reaction to reduce NOx.
Regenerating the DPF involves pulsing the injectors on the exhaust stroke of each cylinder in order to raise EGTs to near 1200 degrees in order to burn off soot accumulated in the DPF.
It will burn more fuel, but will not use more DEF.
Old Apr 25, 2010 | 12:33 PM
  #39
radzer0's Avatar
radzer0
Do you know if it comes up saying something else when its using DEF?
Old Apr 25, 2010 | 01:17 PM
  #40
'96 Bronco's Avatar
'96 Bronco
With almost 800 miles on mine i have been getting between 23 and 24 on the highway with cruise control at 70mph. At night i can get almost 25 when the a/c is turned off and just running vent.
Ive still been told atleast 1000miles before the motor is fully broken in. Some people ive talked too have said there 6.4's they got the best milage at the 2500mile point.
So i guess in a month or 2 i will see if i can manage 25+@70mph
So is this low/mid 20s on a 6.4? if so what year of 6.4.
I really wish I had a 6.7 to around to even think about test driving. I did see a few 2011 super duties at our local ford dealer but I didnt go check to see if any were diesel
Old Apr 25, 2010 | 01:19 PM
  #41
Tom's Avatar
Tom
I do not, but the way I understand it DEF is used very slowly the entire time the engine is running.
The 6.7L engine uses some different engine control settings that vastly improve efficiency. Two that I can think of off the top of my head are vastly reduced EGR as well as advancing the ignition timing. Both of these make it easier to make more power as well as helping efficiency. The downside is that the engine produces quite a bit more NOx this way.
The SCR exhaust aftertreatment system is what makes this possible. It converts the NOx after it leaves the engine before it leaves the tailpipe. So the way I understand it the SCR system(which uses DEF) is active the entire time the engine is running.
Old Apr 25, 2010 | 02:05 PM
  #42
radzer0's Avatar
radzer0
Its a 6.7. Picked it up 2 weeks ago tuesday.
Old Apr 25, 2010 | 04:53 PM
  #43
'96 Bronco's Avatar
'96 Bronco
Thats good to hear out of these new trucks. Im glad all the hype isnt just hype and there are some real facts to back up Fords claims
Old Apr 25, 2010 | 05:07 PM
  #44
F350-6's Avatar
F350-6
That doesn't sound good. One of the benefits of having Urea injection is it's supposed to reduce the amount of regen's. What does your mileage look like with this going on all the time now?
Did you drive it long enough for the regen process to complete, or did you shut the truck off in the middle of a regen process?
Old Apr 25, 2010 | 05:22 PM
  #45
radzer0's Avatar
radzer0
I know the first time it came up yesterday i turned it off shortly after. But one of them i know the truck was on atleast 10min after. the 2nd time it was on for maybe 45min after. i didnt pay that much attention on the others.
As for milage when its doing a regen, I never reset it to check. Ill try to keep that in mind for in the future tho when it pops up to reset and see compared to what i had before.
