1978 - 1996 Big Bronco
New 79 Bronco pics!
Old Dec 7, 2010 | 05:05 PM
str8piped79's Avatar
str8piped79
New 79 Bronco pics!
This is my new truck and I'm excited and wanna show it off a lil Actually I was thinking about buying new coil springs for the front, how much lift could I go without having to buy the drop brakets?
Old Dec 7, 2010 | 07:57 PM
str8piped79
BTW I only paid $500 for it
Old Dec 7, 2010 | 09:42 PM
Encho's Avatar
Encho
The Southernmost Mod
Nice Project, those years Broncos are the best lookers.
Old Dec 7, 2010 | 09:48 PM
greystreak92's Avatar
greystreak92
Lift the front no more than about 2" without either having to use the drop brackets and/or change C-bushings. Any more lift without correcting for changes in caster and you will just eat front tires in a hurry. 2" should actually level the truck off with it empty. Ford trucks ride high in the rear because Ford assumes its customers are going to load their trucks with something and once loaded, the truck would ride more level. However, if not, then 1.5-2" of lift up front should level it off.
Old Dec 8, 2010 | 08:30 AM
str8piped79
Thanks encho, I agree. and greystreak, that's about high I was thinking, bronco graveyard sells the 1-2" lift springs for cheap. If I don't do that I'm gonna try to get a 4" sus lift :]
Old Dec 8, 2010 | 05:50 PM
greystreak92
If you do go for the 4" suspension lift, keep the point about the "higher in the back" in mind. I asked specifically about that when I was researching lift kits because I wanted to end up with a truck that appeared to ride level when I was finished with all that work. I found that Tuff Country and one other lift manufacturer were taking that point into consideration at the time. I don't remember the other lift manufacturer because I went with the Tuff Country kit.
Old Dec 9, 2010 | 12:39 PM
str8piped79
I'd like it to sit bulldog(where the rear end sits lower than the front) but I don't know if any lift manufacturer has kept that in mind.
Old Dec 10, 2010 | 07:27 AM
cje07's Avatar
cje07
WOW! $500 was a steal! Nice looking rig!
Old Dec 11, 2010 | 12:50 PM
str8piped79
Thanks! It's my second bronco, I've always loved 'em since I was a kid(i'm 20 now) I talked the guy down from $750 :]
Old Dec 11, 2010 | 06:02 PM
jacfordf-250's Avatar
jacfordf-250
great looking bronco
Old Dec 12, 2010 | 01:47 AM
greystreak92
You can always add a leveling kit in addition to the longer front coils if you really want that look. I think Energy Suspension still makes a 1.5" leveling kit that consists of a pair of polyurethane discs and a pair of short stub extensions for bolt that holds the bottom spring collar down. This puts the disc below the spring against the top of the axle.
Old Dec 14, 2010 | 04:19 PM
superboy54's Avatar
superboy54
Nice ride for a nice price. Out here where i live 78 and 79 broncos run from 5,000 up to 15,000. 5,000 being a nice bronco project to start off.
lucky_thirteen
15
Mar 7, 2024 11:22 AM
79 F-150 Stone
36
Mar 23, 2017 12:27 PM
Arnold Kenyon
Aug 26, 2016 04:21 PM
F350Loui
Jun 27, 2016 12:56 PM
dynamic
58
Apr 27, 2016 01:38 PM
