1978 - 1996 Big Bronco
gear swap
Old Dec 12, 2010 | 12:51 PM
murph_murphy's Avatar
murph_murphy
gear swap
hey i have a 92 bronco that i want to change the stock gears out for a 4.11 or something along those lines cause right no i have the stock gears and run 33x9.5x15. i could use some extra power but would it be cheaper to just go down tire size to 32s if that would make a big difference, it is my daily driver and i like to hunt and off-road, also i need fairly good gas mileage i don't want to lose more than 2 mpg. so any advise would be great guys. also i am looking at getting a daystar leveling kit 2 inches so i could run 33s if i get the 4.11s either way im getting the leveling kit if it is recommended (just thought id throw that in). thanks for looking
Old Dec 12, 2010 | 06:27 PM
g_k50's Avatar
g_k50
Use the tire size shown on the door tag, that's the best for the type of driving you want to do. Skip the lift.
Old Dec 12, 2010 | 08:19 PM
Kemicalburns's Avatar
Kemicalburns
31's should be what you roll back to if you want mpg in your current setup with out going to a gear swap.
33's can fit with out lift on your year bronco but 4.10's should be considered.
Old Dec 12, 2010 | 11:21 PM
greystreak92's Avatar
greystreak92
Definitely agree with making the swap to 4.11's. (And yes the D44 ratio is 4.10:1 and the 8.8 ratio is 4.11:1). Personal experience says that making the move to 33's without re-gearing causes the E4OD to "hunt" furiously between 35-45 mph. So 3-4 shift point hunting gets pretty silly and passing/hill climbing power suffers tremendously.
Old Dec 13, 2010 | 03:20 PM
murph_murphy
another quick question how much would it cost ruffly if i have a mechanic do it but i buy the part or would it be easier to let the mechanic do everything for me. what would be the cheapest way of doing that.
thanks for the advice
Old Dec 13, 2010 | 04:11 PM
Kemicalburns
depends on what the shop adds for markup. if you get all the right parts no reason why a qualified shop couldnt do the install. Shop around though and ask a few local 4x4 clubs who they recommend. be carful of chain shops like 4wp for instance.
Old Dec 13, 2010 | 08:03 PM
murph_murphy
is the 4 wheel parts stores not good at installing or over priced?
Old Dec 13, 2010 | 10:06 PM
greystreak92
Lazy techs and run-of-the-mill installation practices. Typical chain-store issues. Remember, it only takes one sloppy gear setup to turn $200 worth of gears into $20 of scrap metal.
Old Dec 14, 2010 | 04:24 PM
murph_murphy
ah. alright i will be careful on who i will have it done for me. thanks for the tip.
reddogracing
Oct 19, 2011 02:19 AM
Cowboy34
Nov 9, 2005 12:05 PM
84FB351
May 18, 2004 10:36 PM
Ford7875
Dec 26, 2002 02:43 PM
79_ford_400_guy
Apr 2, 2002 06:22 PM
