1984 f150 retrofit
1984 f150 retrofit
I have a 351w with a two barrel carb. . I get horrible gas mileage(9.7mpg). As I have antique tags I no longer have any emission restrictions. My question is what type of carb and distributor should I get so I can bypass all emission hookups. Can I use my present carb after plunging off certain ports. Can I use a distributor from a previous year. Any input would be helpful.
I would tell you to get a 4bbl carb either Motorcraft/Holley or Edelbrock. Once a tune up is done and the carb dialed in correct you should be good to go. For ignition I would run a duraspark 2 system. There are some threads here about it, it is supposed to up mpgs, give more power, and require less work on your starter. In reality I would figure your truck would pry max out on mpgs some where in the neighhbor hood of 12-15. Supposedly by 460 big block gets 10-12 according to the previous owner which I would be really happy with.
1984 F150 retrofit
I would say the biggest reason for your improvement probably came from the carburetor and a better ignition advance curve. The advance curve can be done with the Duraspark distributor very easily, the basic internal advance system hasn't changed since the late 50s.
Ryan Hankins
08-17-2013 07:59 PM
85fordf150blue
10-15-2011 07:19 PM
stangfan78
06-25-2008 07:59 PM
stangfan78
06-23-2008 09:09 PM
