Carb and Intake Replacement
Old Jun 25, 2008 | 12:29 PM
stangfan78's Avatar
stangfan78
I recently put a 351W from an 85 Bronco into my 80 F100. I removed all the emissions and the truck runs ok. Over the weekend I discovered that the carb is leaking gas in the back on to the intake. Its a Holley 4BBL 4180, after a little reading on here I found they are prone to leaking and best if replaced. I am thinking of going with an edelbrock performer intake and 1406 carb. The problem is I have never tried this before. The things I am concerned with are pulling the distributor because I haven't set timing before and adjusting the carb. Does anyone know the steps for replacing the intake as well? I would like to try this myself if I can get all my questions answered. Thanks for any input you may have.
Old Jun 25, 2008 | 07:59 PM
LxMan1's Avatar
LxMan1
It's pretty straight forward. Just clean the gasket surfaces on the heads good before installing the new set-up. And use RTV sealer on the end gaskets. A manual like a Chiltons or Haynes will give you the proper torque sequence.
strokin'_tatsch
76
Jun 15, 2018 05:27 AM
DoesItReallyMatter?
85
Apr 23, 2014 07:32 AM
projectbad78
Apr 6, 2009 11:36 PM
hacking_in2002
16
Dec 10, 2008 10:56 PM
chimpbike
Jun 12, 2007 07:13 AM
