1978 - 1996 Big Bronco
88 hubs
Old Dec 5, 2010 | 06:42 PM
dwcranger's Avatar
dwcranger
88 hubs
Hey guys I just bought an early 88 Bronco with a bad 4wd hub. I bought an NOS set of of ebay to replace both. Is it as simple as removing the wheel and sliding the old one off and sliding the new one on ? Thanks for your help.
Old Dec 5, 2010 | 11:08 PM
g_k50's Avatar
g_k50
No it's not. Is it a bad bearing or is it the hub won't lock on the axle?
Old Dec 6, 2010 | 05:20 AM
dwcranger's Avatar
dwcranger
Selector switch is broke is all. Flange style of course.
Old Dec 6, 2010 | 08:11 AM
redneck94's Avatar
redneck94
You dont need to take the wheel off to repair your hubs... there are 5 or 6 (pends on hubs) bolts allens or phillips drive holding on the cap.... are you replacing the internals? you will need a snap ring tool should have two snap rings one on the shaft and one on the outer of the locker.. than the hub assembly will slide out... when you have it like this you should think about replacing your bearings and spindle lock nuts ( easiest if you have the sockect for them) make sure you pack any part in with grease and its clean.. If you decide to do your lock nuts jack that tire up and remove it so you can check it
Old Dec 6, 2010 | 01:29 PM
dwcranger's Avatar
dwcranger
These are the flange style hubs. They were only used in 87 and early 88. They are a one piece design that,from what I understand,just slide on and off the axle. My question is,is it that simple?
Old Dec 6, 2010 | 02:11 PM
Kmofuggind's Avatar
Kmofuggind
Warn hubs come with a diagram illustrating an exploded view of all ford style hubs (flange style included) I would google the installation instructions or check warn's website/or summitracing.com to see if the installation guide is included/shown online.
ltlblutrk
Feb 24, 2015 08:15 PM
pembo2005
Mar 15, 2013 06:34 AM
rdw516
Sep 20, 2010 07:01 PM
quisp-n-quake
Apr 2, 2008 07:51 AM
stooolieb
Sep 19, 2003 08:51 AM
