Mechanic Question(s)
Old Dec 12, 2010 | 06:08 PM
  #31
04gray350's Avatar
04gray350
Does anyone know the proper way to disconnect the viper alarm on the truck to make sure its not the reason I am not starting
Old Dec 12, 2010 | 10:39 PM
  #32
04gray350's Avatar
04gray350
tried to lock and unlock the truck and the remote start still will not work and the truck still does not start.
Does anyone know if the remote start is wired into anything that would keep the truck from starting just by it going bad???
Thanks in advance
Old Dec 13, 2010 | 08:43 PM
  #33
04gray350's Avatar
04gray350
I am about to give up is there anyone on here work on this type of problem and would be willing to help in my area?????
Old Dec 13, 2010 | 08:56 PM
  #34
04gray350's Avatar
04gray350
ok truck turns over with remote start but it sounds week when turning over.
Old Dec 23, 2010 | 01:41 AM
  #35
04gray350's Avatar
04gray350
YouTube - 04 Ford F350 Diesel No Start
Old Dec 23, 2010 | 02:13 AM
  #36
hubler13f's Avatar
hubler13f
I've been trying to keep up with everything you have going on. Were you ever able to get your hands ons a code reader?
Old Dec 23, 2010 | 02:37 AM
  #37
04gray350's Avatar
04gray350
just the one on a bully dog system. do you know if auto zone or advance will rent it out?
P0113
U0432
P0603
U0603
P1000
thats what it pulled
Old Dec 23, 2010 | 02:43 AM
  #38
hubler13f's Avatar
hubler13f
I know both those places will rent tools out down here and will scan codes for free when the vehicle is at their store but I have never tried to rent their OBD scanner's though.
Does your Bully Dog give you code explanations or just the numbers. I am on 24 hour duty until 0900 so I am bored as hell and will start looking them up if you need the explanations.
Some of the Techs may know the explanations off of the top of their heads, but I don't think any of them are burning the midnight oil tonight.
EDIT: Nevermind I found your other post where they were explained. https://www.ford-trucks.com/forums/1...ease-help.html
Old Dec 23, 2010 | 03:58 AM
  #39
hubler13f's Avatar
hubler13f
I was just reading some of the other forums and noticed that the codes P0603 P1000 and the Bully dog system seem to go hand in hand. If you do a google search with "bully dog P0603" you will find other problems with no starts and rough running trucks that all seem to relate to the bully dog corrupting files as NPCCPartsman stated in another thread. After reading some of the posts on other forums I would lean towards his suggestion of getting it reflashed to stock and it would probably solve your problem.
Old Dec 23, 2010 | 08:12 AM
  #40
gearloose1's Avatar
gearloose1
Originally Posted by npccpartsman
I saw this in another thread: You might check under the airfilter for wire chaffing. You could have a harness problem there causing CMP/CKP sensor issues which would cause a no start. Did you ever get a scanner to check for codes?
I had a similar issue with my 04 that I never found the cause of. I walked out one morning and it just wouldn't start for no apparent reason. I spent the day going through harnesses looking for chaffing, bad connections, etc. Checked the PCM/TCM connections, rewrapped/overhauled the FICM harness, EVERYTHING I could find with no apparent issues. Plugged it all back in and reassembled everything and the truck fired right up. I never did find the issue and have had no problem since (knock on wood). I know this doesn't really help, but similar experience.
Classic electrical / connector problem.
Or, a glitch that was fixed by the power down / system reset you did along the way.
Old Dec 23, 2010 | 08:35 PM
  #41
04gray350's Avatar
04gray350
Di you check out the youtube video that I posted? Do yours sound like that when it didnt start?
Old Dec 23, 2010 | 09:52 PM
  #42
04gray350's Avatar
04gray350
when I called BullyDog they told me those were codes that there system caused to happen and they are fine. I promise if I get new software from ford and it corrects it I will be going to the main office!!!! LOL
What if I try to put a different programmer on it??? Could that fix it?
Old Dec 24, 2010 | 08:38 AM
  #43
69cj's Avatar
69cj
Why would it be Fords fault if the BD or viper corrupted the software??
Old Dec 24, 2010 | 08:59 AM
  #44
04gray350's Avatar
04gray350
Not saying it is Fords fault just want it corrected. LOL
Old Dec 24, 2010 | 09:39 AM
  #45
06silvercrew's Avatar
06silvercrew
Im not familiar with the bully dog, is it a programmer or a inline module? start with basics, the truck needs to be flashed back to stock or the module removed, and I always disable any aftermarket alarm/remote starts before going any further with the diag.
cope1972
Dec 14, 2014 09:01 PM
dixoncity
6.7L Power Stroke Diesel
Jul 26, 2011 10:20 PM
crazer42
16
Oct 16, 2010 07:24 PM
babybluef100
Aug 15, 2009 01:05 PM
Chris Iverson
20
Feb 22, 2004 06:54 PM
