Mechanic Question(s)
Old Dec 7, 2010 | 08:06 PM
cheezit's Avatar
cheezit
a puff of smoke when started in cold weather is normal. I get a small black cloud
Old Dec 8, 2010 | 03:22 AM
npccpartsman's Avatar
npccpartsman
Originally Posted by 04gray350
Thanks will check that tomorrow. If there is not fuel in there whats that mean???
It means your fuel pump has gone out or the fuel has drained back to the tank, which mine does. Starting on some of the latest 04 models the fuel lines were changed to help prevent that.
Pull the secondary lid and have someone cycle the key for a couple of seconds--it may take less. The housing should fill VERY quickly. If it doesn't then you have a fuel pump problem of some kind. CAUTION--FUEL MAY SPRAY SO USE PROTECTION!!!!!!!!!
Old Dec 8, 2010 | 07:29 PM
04gray350's Avatar
04gray350
checked the cap and its full of fuel? any ideas?????
Learning as I go so anything helps! Thanks in advance
Old Dec 8, 2010 | 07:33 PM
04gray350's Avatar
04gray350
I just noticed tonight that the motor that runs on the passenger side when the key first turns on sounded different. What is it and whats it do???
Old Dec 9, 2010 | 10:45 PM
04gray350's Avatar
04gray350
Old Dec 9, 2010 | 11:39 PM
bismic's Avatar
bismic
It is your vacuum pump - nothing to do w/ the no-start.
No rpm's when cranking indicates a possible issue w/ the CKP. The sensor itself doesn't fail that often - the connector and wiring has a higher failure rate - although infrequent, there are crankshaft sensor failures.
Old Dec 10, 2010 | 02:57 AM
04gray350's Avatar
04gray350
were is it at so I can check it????
Old Dec 10, 2010 | 07:50 AM
04gray350's Avatar
04gray350
Pics would be a big help
Old Dec 10, 2010 | 08:01 AM
bismic's Avatar
bismic
They are in one of my picture albums. You can look through them, do a search, or wait an hour or so and I will post the link (going to work right now).
Old Dec 10, 2010 | 08:37 AM
04gray350's Avatar
04gray350
OK found pics will have to be Sunday before I can get to it? Any tips to get to the clip so I can check the wires?
what would be the next check after this????(just in case)
Old Dec 11, 2010 | 10:47 PM
04gray350's Avatar
04gray350
will be checking the ICP tomorrow on the valve cover to see if that does anything.
Old Dec 12, 2010 | 05:34 AM
npccpartsman
I saw this in another thread: You might check under the airfilter for wire chaffing. You could have a harness problem there causing CMP/CKP sensor issues which would cause a no start. Did you ever get a scanner to check for codes?
I had a similar issue with my 04 that I never found the cause of. I walked out one morning and it just wouldn't start for no apparent reason. I spent the day going through harnesses looking for chaffing, bad connections, etc. Checked the PCM/TCM connections, rewrapped/overhauled the FICM harness, EVERYTHING I could find with no apparent issues. Plugged it all back in and reassembled everything and the truck fired right up. I never did find the issue and have had no problem since (knock on wood). I know this doesn't really help, but similar experience.
Old Dec 12, 2010 | 12:56 PM
  #28
04gray350's Avatar
04gray350
I just checked the part on the valve cover on the passenger side. no change in it at all.
It blows my mind to know that all of us ford owners have this and no quick fix LOL
Old Dec 12, 2010 | 01:07 PM
  #29
bismic's Avatar
bismic
The Crank Sensor drives the tach. If the tach isn't moving, the crank sensor is likely to have died (CKP) or have bad wiring.
Located underneath the A/C compressor. It is very hard to get to. You need long skinny arms for the job. FYI - it is easier to unplug the sensor with it in the hole. The o-ring can fail and the connector can get oil soaked and fail.
Old Dec 12, 2010 | 06:03 PM
  #30
mhoefer's Avatar
mhoefer
Try unlocking and locking using your remote, this will put it in normal operating mode. Now try the remote start.
