Gauges installed, now lighting problem
Old Dec 4, 2010 | 10:11 PM
Waltdog's Avatar
Waltdog
of American machinists
So I just finished installing my gauges. First crack of the key they come right on and light up just fine. Go drive around, check boost ,EGT's Everything seems fine. Now when turn the key on and turn the lights on I get no gauge illumination! Or the top gauge(trans temp) will light up while the two below it are dark. Eventually the bottom two will flicker on
Also with the motor running and lights on if I hit the window up switch while the windows are already up the gauge illumination turns off and the heater fan decreases in speed.!!
The only thing I can think of is a wire not being seated fully in a plug.?? Maybe flux on the ground eyelet that I soldered on?? I used the potentiometer harness. Black wire to chassis ground, orange to dimmer wire in headlight switch and red to red w/yellow tracer on the AIC plug. Each gauge has its own ground ,power and illumination , I did not daisy chain those three wires
Has anyone experienced a situation like this?
Old Dec 5, 2010 | 12:06 PM
Waltdog's Avatar
Waltdog
The problem was the potentiometer was turned down to low
Old Dec 5, 2010 | 01:42 PM
Rushmore X's Avatar
Rushmore X
at least it was an easy and cheap fix...
Old Dec 5, 2010 | 01:53 PM
milleroutdoors's Avatar
milleroutdoors
Glad you found it.
Cory281
Aug 5, 2012 11:09 PM
TexasRenegade
13
Mar 28, 2011 03:59 PM
TennesseeMustangPerf
Mar 21, 2010 09:10 PM
MoyockPowerstroke
Jun 15, 2009 06:29 PM
bandlgeorge
48
Feb 2, 2008 12:24 PM
