390 power upgrades
Old Dec 4, 2010 | 08:53 PM
Lil Red Sled's Avatar
Lil Red Sled
390 power upgrades
Just wonder some good ways to really see some horse power out of my 1976 F250 390. Any one have some good ideas? It all stock except a new 4 barrell carb. Thanks
Old Dec 4, 2010 | 09:17 PM
410F-100's Avatar
410F-100
Headers are a good start, Iv got a brand new set that im too lazy to install and willing to sell...
dual exhuast
alumnium intake and heads if you have the cash layin around.
rv camshaft and straight up timing chain
MSD ignition
port match heads and intake and polish on the exhaust
the list can go on and on
Old Dec 4, 2010 | 09:24 PM
91dirtydiesel's Avatar
91dirtydiesel
Run race fuel
Old Dec 4, 2010 | 09:39 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
dual exhuast
MSD ignition
Headers and exhaust provide the most bang for the buck.
The factory "T" 4 barrel intake is actually pretty good for a DD/ mild engine build. Of course it weighs 70 pounds unlike the aftermarket aluminum at 30.
All FE timing sets are "straight-up"
I would consider the MSD a step down from the Durapsark.
The factory iron heads aren't too bad with a pocket port/ bowl blend.
Of course if you win the lottery...
Josh
Old Dec 4, 2010 | 09:45 PM
HIO Silver's Avatar
HIO Silver
Bang for the buck?
Stage 1.
600 to 650 cfm carb, dual plane intake, headers & dual 2.5 inch exhaust, K&N air filter. Spot-on tune up (mixture, timing, jets).
Stage 2. Aluminum cylinder heads and lumpier camshaft. 3-inch exhaust
Stage 3. Fast XFI Fuel Injection and a bottle of NOS.
Stage 4. Contact Survival Motorsports
Old Dec 4, 2010 | 09:57 PM
410F-100's Avatar
410F-100
Josh
Ummm I was under the impression that after 72 the gov. mandated that the timing be set at 4* retarded due to the B/S reason of better emissions...
Old Dec 4, 2010 | 10:10 PM
Bullitt390's Avatar
Bullitt390
Hmmm... maybe for the car engines. Stock FE sets are "straight-up" and all used the same timing chain from 1964-1976... C4TZ-6268-A
Can't speak for the Windsors, Modifieds or 385 series.
Josh
Old Dec 5, 2010 | 01:50 AM
Lil Red Sled
Thanks guys. I'll probably start with some headers and exhaust and go from there
Old Dec 5, 2010 | 04:41 AM
monsterbaby's Avatar
monsterbaby
moved into the FE forum
Old Dec 5, 2010 | 07:42 PM
427 fordman's Avatar
427 fordman
Originally Posted by 91dirtydiesel
Run race fuel
Won't do anything but put a bigger hole in your wallet unless you have higher compression..
74f100sc
15
Feb 23, 2016 11:26 PM
Björn
Jan 19, 2014 08:53 AM
FossenRacing
26
Jan 14, 2012 10:37 PM
cowboy.2010
29
Feb 8, 2009 05:13 AM
ford390gashog
Oil & Lubrication
Jul 4, 2004 02:44 PM
