RE: Tranny Guide in Tech Article section
Old May 9, 2004 | 05:59 PM
  #46
camarokid81's Avatar
camarokid81
re ratio
the stock factory gear ratio in a c6 transmission is as follows
1st gear 2.46:1
2nd gear 1.46:1
3rd gear 1:1
if you get a wide ratio gear kit you can change it to be lower and make the transmission almost bulletproof. i have done extensive work on my c6 and still not done yet. i`am trying to eliminate all the friction i can because it takes about 70hp to run a c6 transmission in stock form. i have replaced the brass thrust washers with turrington bearings changed the output housing to a needle bearing instead of a bushing (from a lincoln) installed a 6 pinion front planetary (stock in only3) have found a orignal ford 5 clutch forward drum (stock is 4) updated the rear planet to a 4 pinion instead of stock 3 and installing heavy duty e40d(4r100) internals fron big block or diesel should last forever behind a 302
the wide ratio gear ratios are as follows
1st gear 2.72:1
2nd gear 1.54:
3rd gear 1:1
Old May 10, 2004 | 05:19 PM
  #47
archangel's Avatar
archangel
original ford 5 clutch forward drum (stock is 4)
[B] Actually, the heavy duty is four clutches and most regular duty are only three so you made a score.
Updated the rear planet to a 4 pinion instead of stock 3
[B] The best one is the steel 6 planet in the new Super duty (F450 and up) but the Aluminum 4 planet is good for 500-600Hp I am told.
Also you might want to get the 'R' code servo piston set up from Ford motor sports so the band will keep up with the rest of the trans.
Old May 31, 2004 | 07:52 AM
  #48
outlaw50's Avatar
outlaw50
pleas send your guide.
I cant email you yet due to site restraints. CAn you click on my user name and send it to me? If not send to mark.e.delozier@jci.com
Thanks. I am contemplating changing from E4OD to 5 speed.
94f250 351 4x4.
Mark
Old Jun 8, 2004 | 12:43 PM
  #49
SgtJoe's Avatar
SgtJoe
Good list. Could you email it to me? brandonmoody@mindspring.com Here's some more info to help the list. The 4r44E/4R55E were also used in the Aerostars. I'm not sure what year they switched from the A4LD but I know the 87 model had one, and my 96 has a 4R55E. Once again, good job!
Old Jun 11, 2004 | 09:27 PM
  #50
ferguson777's Avatar
ferguson777
To anyone that has recently posted a request in here for me to email the complete version to you -
I rarely venture into this forum anymore and this thread in particular. If you want the full version, then email me via
the_fergusons @ sympatico.ca
remove any blank spaces in the address above.
Later,
Old Jun 19, 2004 | 11:49 PM
  #51
slowride59's Avatar
slowride59
Copy of Trans Guide
Hi Everybody, Hey, Ferguson 777 could you send me a complete copy of you trans guide? I can't Email you direct because I haven't made 15 posts yet. Thanks, slowride59
Old Jul 31, 2004 | 02:44 AM
  #52
67fastbackfreak's Avatar
67fastbackfreak
Question wait a second
umm...what was that email address??? i want that stuff i dont care if its a little innacurate. this would be very very useful. thanks
Old Aug 7, 2004 | 12:44 PM
  #53
covetsanes's Avatar
covetsanes
Thanks for the effort. I FINALLY was able to pin down the model transmission in my 90 f150.
chuck petterson
persia, Iowa
Old Sep 29, 2004 | 07:58 PM
  #54
cdawley4's Avatar
cdawley4
4r70w
Hi,
When I did my first tranny fluid and filter change at 30k miles, I went to my local auto parts store and told them what I had and they told me to go to the dealer. I called the dealer to find out what kind of tranny I had and they said I had an AODE. After looking at the tranny pan last night, I realized that I had a 4R70W with an orange TSB 98-4 sticker on it. All of my other fluid and filter changes, I have been able to get the fluid and filter at my local auto parts store after the 30k mile change. I now have 134k miles on the truck and it still runs good. I have minor tranny problems that I posted and hope I can find the answers here on FTE.
Thanks,
Chris
Old Oct 1, 2004 | 08:34 PM
  #55
halsey's Avatar
halsey
Halsey
info on 1984 f 350 diesel RV auto 3 speed HD. horse power Gear splitter such as gEAR VENDER OR us gEAR ETC. ANY AND ALL INFO cLASS C bORN FREE I'M TOLD CHASSIS IS A 1984. SHORT OF HP IN THE big hills
THANKS FOR ANY HELP ON THIS
Old Oct 7, 2004 | 09:02 PM
  #56
maxine-70's Avatar
maxine-70
Dad had a motor home years ago that was a 95 and it had a 460/c6. Was definately c6 though, he had to replace it shortly after buying it
Old Oct 20, 2004 | 06:19 PM
  #57
Goliath 350's Avatar
Goliath 350
hello,
i am new to this forum, so i cant send a E-Mail to get the tranny guide you are offering. I was wondering if anyone could help me find out what tranny i have.
1997 F-350 reg cab 4x4 7.5L automatic w/overdrive. Push button overdrive selector on the gear shifter.
Old Oct 20, 2004 | 06:46 PM
  #58
White Noise's Avatar
White Noise
Hey Ferguson 777 I'm a new user and can't email you myself; if you could send me a copy of the trans guide I would very much appreciate it.
Old Oct 21, 2004 | 04:25 PM
  #59
halsey's Avatar
halsey
hi halsey here
you can give the VIN number to manufactuer and they can give you any info on your truck providing nothing has been replaced. there also should be a metal tag bolted on each end of the rear end. I don't know if I don,t know how to post but I never have receied any info about what is best drive train for mountain and interstate driving for a 1984 E- 350 c6 3 speed automatic diesel dually Class C motor home. Would like a gear splitter with overdrive, Surely someone out there has some info on this, don't you all answer at once. live in iowa so hills aren't bad here but southern mo and ar is where we need some help thank you all Halsey
Old Oct 21, 2004 | 08:21 PM
  #60
dorianrey's Avatar
dorianrey
Unhappy
i got a 2000 f1504x2,the tranny starting to slip, how much you think im gona spend to fix it or replace it, and do you know about anywhere in san diego i can get that done at a reasonable price, im in the military, dont make uch you know
