RE: Tranny Guide in Tech Article section
Old Oct 21, 2003 | 05:51 PM
  #31
ferguson777's Avatar
ferguson777
Since they no longer allow email addresses in the threads - if you want to get ahold of me - go to my profile and send me an email message from there.
Later,
Old Oct 24, 2003 | 12:45 PM
  #32
1990Fordf150v8's Avatar
1990Fordf150v8
ferguson777
Can you please e-mail me that chart you have. My e-mail is jackmutch@hotmail.com THANKS
Old Nov 6, 2003 | 12:29 AM
  #33
ketama's Avatar
ketama
Tranny I.D.
I checked out Ferguson's Tranny Spotter's Guide but did not see older trannys mentioned. I have a 1959 F-350 dually with a 292 and 4 speed. I am trying to figure out if I can put a 5-speed in (for overdrive) or a 2-speed rear end (stock rear end (Eaton?) is geared pretty low (4.88?)). I do not know what types of trannys were used back then and if modern trannys use the same bolt pattern.
Also was wondering if engine is worth saving or if I should just junk the whole drive train and drop a new powerstroke diesel or a 350c.i. or something that will mate up with a ZF and call it good.
PS this is my first post... only 24 more posts and I get email privileges
Old Nov 6, 2003 | 07:28 AM
  #34
ferguson777
If you don't get an answer here, try posting your question in the 48 - 60 truck forum. There's a few guys in there that have a good understanding of what later trannys will bolt up to earlier engines, etc.
Regards,
Old Nov 13, 2003 | 04:40 AM
  #35
camarokid81's Avatar
camarokid81
trans stuff
i`am changing an aod to a c6. i have been through 4 aod`s now and refuse to use them anymore. they made c6`s up to 1996. my problem is on the parts locator i`am using says 75-91 sbf c6`s are interchangable. and from 92-96 the locator wants to know if trans has casting F2UP-CA or not. what would be the reason they want to know that (difference) are there different tail shaft housing sizes ? what tailshaft size should be in a 1991 e150 2wd (van) with 138 wheel base c6? also are there variations between the 6cyl and 8cyl trannies (insides)? and what year c6 trans has the best parts in it ?
here is the locator i use
http://www.car-part.com have access to everything
i`am trying to get all this info together to find out what year van to get a driveshaft from
your help would make my life eaiser thanks for your time
Old Nov 30, 2003 | 07:56 AM
  #36
Jeff 88 F350 Diesel's Avatar
Jeff 88 F350 Diesel
How about posting a link?
Old Jan 28, 2004 | 07:59 AM
  #37
Mark Portner's Avatar
Mark Portner
Does anyone now what changes have to be made for a c-6 2wd to be used for a 4wd other than the 2wd extension housing. I am kicking around the idea of a c-6 2wd & a devorced np-205. thanks
  #38
Mark Portner
Old Jan 28, 2004 | 09:19 AM
  #39
archangel's Avatar
archangel
A divorced NP-205?
If I were to do it, I would replace the long output shaft with the flanged one from an older 60's 70's "FE" style C6 trans, but to get to the snap ring that holds the long one in you have to tear it down, so you might as well freshen it up with new seals throughout.
Old Jan 28, 2004 | 12:24 PM
  #40
Mark Portner
a divorced 205 is a gear driven cast iron transfer case seperated from the transmission with a short driveshaft between the transfer case and transmission, not bolted to the transmission like most 4x4s. I kind of figured that was how to pull the shaft. I was hoping I could just give it a quick kick and it would fall into my arms!
Old Jan 28, 2004 | 09:52 PM
  #41
archangel's Avatar
archangel
"seperated from the transmission with a short driveshaft between the transfer case and transmission"
That was why I said I'd use the shorter flanged output shaft, to keep the overall length as short as possible.
Old Feb 21, 2004 | 05:20 PM
  #42
onefut's Avatar
onefut
Hi
could i get a copy of the chart
thanx
onefut
Old Feb 26, 2004 | 01:47 PM
  #43
twoballsleft's Avatar
twoballsleft
I am ordering a 350 PSD 5SP. I was just informed that the tranny guts are different...beefier...if I get the PTO option. Is this true and if so, where can I find some specs?
Old May 1, 2004 | 02:54 PM
  #44
41hracing's Avatar
41hracing
need help on idenity of trans out of 1983 two wheel drive 3 on the tree
Old May 8, 2004 | 07:02 AM
  #45
1987 f250's Avatar
1987 f250
Hello all. Does anyone happen to know what all the gear ratios are for the C-6 transmission. I bought my truck used 7 years ago and never have had to touch this transmission. I never realized how tuff these things are.
Thanks!
