Ranger Hard Starting
Old Feb 16, 2019 | 11:42 AM
  #46
pawpaw's Avatar
pawpaw
Originally Posted by Craig Seybert
Also, I'm not sure how long this has been going on, I just bought the truck. But, Will this have any seriouse negative effects in the short term? I might not be able to fix this right away.
It sure can have other serious consequences. If it's misfiring, the unburned fuel will be dumped into the cat converter for processing & that can cause it to overheat & meltdown the internal converter matrix that processes/reduces unburned hydrocarbons, so it'll fail emission testing & if the matrix overheats high & long enough & breaks down bad enough it'll increase exhaust back pressure & cause the engine to run hot, loose power & otherwise be wimpy when you ask it to go at throttle up, so best to get this problem put right without delay, especially if your using it as a daily driver.
Old Feb 16, 2019 | 12:05 PM
  #47
Craig Seybert's Avatar
Craig Seybert
Thanks for the reply. I will get this fixed ASAP. Also I noticed something, There looks to be oil coming out of the boot in the middle between the 4 spark plugs, do you know what this item is?
Old Feb 16, 2019 | 12:09 PM
  #48
pawpaw's Avatar
pawpaw
I've never owned the 4banger, so I'm not familiar with how this puppy is plumbed, but we have plenty of members with this engine, so maybe one reading your post will chime in & enlighten us about what it is & why it might be leaking oil.
Old Feb 17, 2019 | 09:36 AM
  #49
Craig Seybert
PAWPAW thanks for the tips. I figured out the cause of the Oil backup. I drained the oil today, 5 quarts came out.... only 4 are supposed to go in. I feel so ashamed. I mis-read the capacity last time I changed the oil. I ordered my parts today. New wires, distributor, gasket and intake gaskets. anything else I should do while i'm opening up this beast?
Old Feb 17, 2019 | 10:18 AM
  #50
pawpaw's Avatar
pawpaw
Have you installed a new PCV valve yet? If not & aren't sure if its due, or if its ever been changed, I'd consider doing it now. & be sure to check its rubber hose for a loose fit & its outer elbow bend for dryrot cracks, etc. If its condition looks questionable, replace it too because if the PCV system leaks it'll corrupt fuel trim & ingest dirt.
Old Feb 17, 2019 | 10:23 AM
  #51
Craig Seybert
Thumbs up
I have not done PVC, I will add that to the parts list. and check all hoses. Thanks again!
Old Apr 8, 2019 | 07:39 PM
  #52
Craig Seybert
PAWPAW, Thank you for the help, I have change all the parts mentioned.
List:
New Fuel filter(First thing I changed when hard crank started)
* Found out about the excess oil in the pan *
Changed the following after my mistake:
Valve cover Gasket
intake gasket
PCV Valve
new plugs
new wire
new distributor
AND THE VERDICT IS:
LIKE BRAND NEW!!!!
Thanks again for all your help. This truck starts like the day it was made and everything seems to be running smooth, no more hard start!
Old Apr 8, 2019 | 07:49 PM
  #53
pawpaw's Avatar
pawpaw
Ok good feedback & to hear all now seems well & your on the road again!!!
Tnewton12313
30
Aug 25, 2016 01:04 PM
Golden Helmet
21
Sep 29, 2013 10:09 AM
cowman435
Aug 22, 2011 06:36 PM
Randy1229
Mar 13, 2011 12:30 PM
retreat
20
Jun 7, 2010 11:45 AM
