whats the dif
Old Mar 2, 2003 | 10:29 AM
Brian68's Avatar
Brian68
whats the dif
I was warned aginst putting an 86 engine into my 89 f 150. is this true or are there just too many conversions to make? whats the dif?
Old Mar 2, 2003 | 11:22 AM
mantta's Avatar
mantta
whats the dif
Yes, the 86 engine is not fuel injected, it is carburated. This means you would have to change your entire fuel system to a high pressure system. You would also need the computer and wiring.
Old Mar 2, 2003 | 12:19 PM
Racerguy's Avatar
Racerguy
whats the dif
What size engine do you have?
Old Mar 2, 2003 | 05:35 PM
Pastmaster's Avatar
Pastmaster
whats the dif
If it is a 302, it's plug-n-play. The late 85+ 302s are all fuel injected. If it's a 351, it is not as easy.
Old Mar 2, 2003 | 09:00 PM
steve83's Avatar
steve83
whats the dif
The biggest reason not to put an '84-86 engine in an '87-89 truck is that the connectors don't match. You're better off with an '87-91 engine, but if you can get the gas tanks & fuel lines, too, go for '90-91 so you don't have the crappy tank select valve and extra fuel pump. It'll involve a little extra wiring, but it's worth it. For the most bang-for-the-buck, get a '95-up MAF engine, but be prepared for LOTS of wiring mods.
Buck268
Oct 11, 2016 03:39 PM
bigcrunch
1997 - 2003 F150
Jul 8, 2016 09:29 PM
Bob Crain
Mar 21, 2007 07:26 PM
Goodold71
May 1, 2005 09:57 AM
offroadguy56
Exhaust Systems
Sep 2, 2003 08:27 PM
