Dana 70 info. needed
Old Apr 30, 2005 | 09:28 AM
Goodold71's Avatar
Goodold71
Question Dana 70 info. needed
I recently found a Dana 70 dual rear wheel dif complete in a 74 F350. I was wondering how hard it is to turn a drw into a single rear wheel ?What components would I need? It is complete drum to drum. I pulled the dif cover and the ring gear reads Dana 70 u and followed up by many numbers.Thanks.
Old Apr 30, 2005 | 09:59 AM
Hooker Bob's Avatar
Hooker Bob
In most cases you can just bolt one wheel on and be done with it. If your wheel will clear the drum the bolt pattern should be the same.
Pat
Old May 1, 2005 | 09:57 AM
51dueller's Avatar
51dueller
I've put a the same axle in my '51 ton truck and I'm currently running the stock single wheels on with no problems.
anthony myrick
Ford Truck Parts for Sale
16
Feb 21, 2017 07:50 AM
ryank59701
Apr 18, 2016 12:46 AM
bill rancharo
Aug 1, 2015 02:48 AM
f150_514ci
Jan 6, 2006 12:06 AM
51dueller
Jan 29, 2005 12:29 PM
