77 rear window?
Old Dec 3, 2010 | 03:56 PM
Farmall05's Avatar
Farmall05
77 rear window?
Im re doing my 77 f100 and removed the rear window to replace it and the rubber seal and found some rust holes under the rubber. how should I go about fixing this I have the cab gutted at the moment should I cut it ount and weld in a new peice or dose anyone have any other ideas, thank
Old Dec 11, 2010 | 09:30 AM
Witty73's Avatar
Witty73
can you post some pictures? I have a cab that had some small pinholes in the same place as you. I sandblasted them as clean as I could from the outside, and filled the holes with fiberglass filler. the fiberglass filler is waterproof, where regular plastic filler is not. it worked out pretty good in my opinion. Others will caution you to cut it out and replace it. I agree to some extent, however, when you weld in the new patch, you will not be able to protect the new weld from the backside with any primer...therefore, that area will begin to rust as well. Tough decision, good luck with the repair.
cparks
15
Oct 6, 2013 04:03 AM
those70'sfords
15
Feb 12, 2008 02:16 AM
fairlaniac
1983 - 2012 Ranger & B-Series
Dec 7, 2007 12:32 AM
Truxx1956
Oct 9, 2007 05:17 PM
Vin Man
Feb 1, 2003 03:39 PM
