Ranger rear window removal
Old Dec 6, 2007 | 09:35 PM
fairlaniac's Avatar
fairlaniac
I'm picking up a '89 Ranger this weekend. It'll be my beater truck, it should be a fun little truck. The truck I'm getting has on half of the sliding rear window broken out. It's an extended cab. How is the window fastened in? I have seen posts that I'ce searched where some are bolted and some are just held in by the rubber seal. There is a '90 Ranger in the local wrecking yard with a flat glass rear window and one with a sliding window. I'd like to see if the flat window would fit. Would it?
Thanks,
Old Dec 7, 2007 | 12:32 AM
michigan66's Avatar
michigan66
In checking a parts catalog, the same sliding rear window is used from 83 to 97. The only case where the window is different is between a standard cab and an extended cab. Each uses a different window.
Airborne-F250
Jun 3, 2017 12:18 AM
Broncogirl18
1978 - 1996 Big Bronco
Sep 22, 2016 09:32 PM
ddeflyer
Jul 23, 2016 04:58 PM
CG-ITS
Feb 21, 2016 09:53 AM
DirtyLarry
Jun 20, 2015 06:51 PM
