injector came apart
Old Dec 2, 2010 | 04:48 PM
1bigjoe's Avatar
1bigjoe
injector came apart
got a new set of injectors, but when i was taking the old ones out, the bottom part of 2 of them unsrewed and the bottom are still in the injector holes,,, i can't be the only one this has happened to, what did you do?
got them squirted pretty good with pb blaster,, what will tomorro bring all ideas welcomed
Old Dec 2, 2010 | 04:53 PM
farmert's Avatar
farmert
Grind the threads off the top piece of the injector, that screws into the head,then thread the injector back together. You can usually break the carbon deposit loose this way.
Old Dec 2, 2010 | 04:59 PM
1bigjoe's Avatar
1bigjoe
that's a good idea -------grinder
Old Dec 2, 2010 | 09:20 PM
ford390gashog's Avatar
ford390gashog
Grind the upper threads off of the old one like mentioned above and insert it in the bore and turn it clockwise and gently pull up it will come right out.
Old Dec 3, 2010 | 07:20 AM
1bigjoe's Avatar
1bigjoe
thanks guys
Old Dec 3, 2010 | 07:31 AM
mechelement's Avatar
mechelement
Grinding the big threads off works. That's what I did.
eatont9999
Sep 14, 2011 03:12 AM
firefighter3129
Jun 7, 2011 08:35 PM
gov2mod
Jul 13, 2008 01:12 PM
tomherrick
Nov 18, 2007 06:53 PM
AndysFords
Oct 4, 2006 10:17 PM
