Axle code?
Old Dec 1, 2010 | 11:44 PM
V-W's Avatar
V-W
Axle code?
Well I've decoded my plate as best as I can but it sais ..... 08 for the axle code which to my understanding is ford 3.50 ratio but there's no code for the front axle?? 4x4 of course. Is this common?
Old Dec 2, 2010 | 07:22 AM
Shoestring's Avatar
Shoestring
Look for a letter near the axle code 08. J designates 2500 limited slip and the K is a 3500. This is for a 1970.
For my 1968 you would see B to L. So it depends on what year model truck you have.
SS
Old Dec 2, 2010 | 09:31 AM
V-W's Avatar
V-W
It is a 70 F100 4x4. There is no letter after 08?
Also the rear being a {08} Ford rearend does that mean it is a 9" with 3.50 gear ratio?
Old Dec 2, 2010 | 02:36 PM
60F100's Avatar
60F100
The front axle code is not always listed. If the door code calls for a 3.50 Ford rear axle your front axle is probably a Dana 44 3.54 which is fairly common. The 3.54 is close enough to the 3.50 to not be a problem. If your truck would have come with the Dana 60-3 rear axle, which is a heavier duty axle than the 9 inch, it would have been a 3.54
Old Dec 2, 2010 | 08:41 PM
V-W's Avatar
V-W
Great to know. I am almost certain that it is a Dana 44. No markings or tags on it. Is there a way to tell for sure? I need a drivers side outer stub shaft and I wanted to make sure I get the right one.
Old Dec 3, 2010 | 09:16 AM
60F100's Avatar
60F100
Go to this website and download the manual
http://www2.dana.com/pdf/X510-SD.pdf
This website has a list of publications. A lot of good info
Dana Holding Corporation The Expert Librarian - Information for driveshafts, u-joints, axles, heavy axles, light axles, Drivelines
If these links do not work pm me.
Joe
Old Dec 3, 2010 | 03:22 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Usually the AXLE code listed on the Warranty Plates of 1965/72 F100/250's is TWO digits, which refers to the rear axle only.
If there is a single third digit, that refers to the front axle.
Dana 60.3 rear axle: Optional in 1966/69 F100's. Not available after 1969.
1970/72 F100: Ford offered two different 9 inch rear axles.
One has a 9" ring gear, 28 spline axleshafts and a 3,300 lb. rear axle capacity. The other has a 9 3/8" ring gear, 31 spline axleshafts, Traction-Lok and a 3,600 lb. capacity.
Only five parts of the 9 3/8" rear axle are the same as the 9: Housing gasket; pinion seal; pilot bearing retainer; (1) pinion bearing and (1) race.
EVERYTHING else is different!
1972RedNeck
Dec 14, 2012 07:18 PM
85camaroman
Jun 10, 2007 08:26 PM
2valvekid
1983 - 2012 Ranger & B-Series
Dec 29, 2005 03:53 PM
Txbullfrog
May 22, 2004 08:46 AM
Jim McCarty
Jul 22, 2003 06:33 PM
