Axle code
Old Jul 19, 2003 | 11:07 PM
Jim McCarty's Avatar
Jim McCarty
Question Axle code
I have a 2000 PSD F250 4WD with axle code TR. Can anyone decode that into an axle ratio?
Old Jul 20, 2003 | 06:50 AM
DCSpecial's Avatar
DCSpecial
Axle code
I don't think that TR is your axle code since here is a list of AXLE CODES
But, on a SRW PSD the only option would be 3.73 gears. The code would help you to know if you had a limited slip or not.
Or look at the tag on the rear diff cover....the second line should start either 3 73 or 3 L 73 if you have the limited slip. Just FYI, sometimes the first number is covered by one of the diff cover bolts.
Hope this helps.
Old Jul 20, 2003 | 06:53 AM
Quadzilla's Avatar
Quadzilla
Axle code
Double check that, Jim. All axle codes are either a two digit number, like 45, or they're alphanumeric, like C5. You might be picking up the trim color code, for example. At least, that was the case pre-'99. If someone else has more accurate information, step up.
Old Jul 20, 2003 | 08:35 AM
johnsdiesel's Avatar
johnsdiesel
Axle code
I'm going to assume that you have the 3.73 since Ford has been offering only the 3.73 with the SRW trucks that have the Power Stroke.
Old Jul 20, 2003 | 08:40 AM
DCSpecial's Avatar
DCSpecial
Axle code
Jim McCarty,
I looked at my truck sticker and it says "TR" to the right of "AXLE"........you want to look at what is listed below "AXLE"....it should be 31 or C1.
Old Jul 21, 2003 | 09:21 PM
KING's Avatar
KING
Axle code
What gear ratio is a C5?
Old Jul 21, 2003 | 10:10 PM
johnsdiesel
Axle code
The C5 is a 4.09 limited slip that was offered only, I think, in the Econoline vans.
Old Jul 21, 2003 | 11:41 PM
KING's Avatar
KING
Axle code
That's what my dad's 96 F-350 sticker reads.
Old Jul 22, 2003 | 11:39 AM
DM1's Avatar
DM1
Axle code
I also have a 2000 F250 extended cab with the V10. My vehicle label mentions TR for springs but I do not know what that means. If someone can shed light on that I would appreciate it greatly.
Old Jul 22, 2003 | 11:44 AM
DM1's Avatar
DM1
Axle code
I have the same TR rating on my 2000 F250. What does that exactly mean? Thanks.
Old Jul 22, 2003 | 12:03 PM
xanthias's Avatar
xanthias
Axle code
On the certification sticker on the lower doorpost behind the driver's door, under "SPR". There will be a two-letter code. The first letter is the front springs, and the second letter is the rear springs. On a 4x4, the front spring codes are:
S = 4,000 pounds @ground
T = 4,400 pounds @ground
U = 4,800 pounds @ground
V = 5,200 pounds @ground
W = 5,600 pounds @ground
X = 6,000 pounds @ground
Code W front springs are rare on a pickup - usually on gasser F-450s.
Code X front springs are reserved for F-450 PSDs, as well as for PSD pickups with the snowplow pkg.
Rear spring codes are A, B, or C.
A = F-250, '99 thru about midyear 2001.
B = F-350 SRW, plus F-250 since mid-year 2001.
C = F-350 DRW
On the pickups, code B rear springs are rated at 6,830 pounds combined rating @ground. Code A = 6,084. Code C = 8,250.
Old Jul 22, 2003 | 12:43 PM
DM1's Avatar
DM1
Axle code
I have a Fisher 8 foot snow plow mounted on my truck. With the T springs, is this appropriate for my truck or should I invest in a heavier duty leaf springs for the front end? The Ford dealership I bought the truck from said it could handle an 8 foot plow with no difficulty. The front end of the truck goes down an inch or so when I raise the blade off the ground. Thank you.
Old Jul 22, 2003 | 06:33 PM
johnsdiesel
Axle code
I posted earlier that the C5 was a limited slip 4.09 on the Econoline vans at one point, but my 1997 F250 has a C5 that is listed as a 4.10 limited slip.
bigdoggs1
2004 - 2008 F150
May 15, 2017 01:07 AM
KLEO1480
Mar 2, 2013 06:53 AM
revans9295
Apr 26, 2012 10:40 PM
livewire21
Jun 24, 2008 04:23 PM
BlueKnight
Mar 4, 2005 11:54 AM
