header fitting
4WD 1/2 & 3/4 ton pickup, F-150, F-250, F-350 (Light Duty Only)
Years: 65-76
Engines: 352-390
Headers:
Painted - PN 89120
HTC Coated - PN 89126
Elite or Stainless - PN 89830
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Automatic Column Shift - Yes
Automatic Floor Shift - Yes
Standard Column Shift - Yes
Standard Floor Shift - Yes
Footnotes: 4, 6, 138, 166 (3/4 - 1 ton only)
4 = Includes parts necessary to retain emission devices (50-state)
6 = Modify stock exhaust to retain catalytic converter
138 = Will not fit Camper Special or vehicles with front sway bar
166 = Will not fit multi-shock absorbers, factory or aftermarket installations.
Emissions: C, G
C= For vehicles 1964 through 1974 without A.I.R. systems, considered as O.E.M. replacement parts when existing emission controls are not removed from vehicle.
G= 1975-1976 only, 50-state legal for these years only.
_____
I double-checked my rig and the collectors point directly to the center of the crossmember at a slight downwards angle. I had to cut the adapter tube at an angle to level the crosstube under the tranny ... plus provided another inch of clearance. I have radius drop-down brackets on my rig so be mindful of that in this pic:
I went to the shooting range and saw this rig in the parking lot.. It's a 66 F250 with duals going over the crossmember and exiting out the back.. and I mean the back! Looks like the dude relies on the cab tank
Tail pipes
At X member
View Undercarriage to rear. Didn't get a pic of the tubing going over the crossmember but you can tell by its proximity to the T-case that it is close.
Last edited by HIO Silver; Dec 1, 2010 at 09:50 PM. Reason: Revised the last image cuz I got the wrong IMG link.
if you could post any pics of them on that'd be great!
I also took a piece of 2.5-inch tube and placed it along the left frame rail and there wasn't enough room for me. Try it and see if it fits your comfort zone. The items in the way included the parking brake cable, a bracket on the NP435, the NP203, and fuel/brake lines. I wanted ample clearance if ever I needed to get in there hence my decision to route both tubes along the right frame rail.
On the 66 F250 above, the owner ran manifolds with 2.25-inch tubing and had the luxury of a muffler shop to make little bends to adjust the route. Me? I had the luxury of laying on my back, a chop saw, grinder, a level, and a welder.
4 miles from Summit? YOU DOG!!! I AM JEALOUS. Heck, if I lived that close to Summit I'd end up working there!!
And from what you said, you have the drop radius arm bracket on in the picture, so it looks to me like i would have the room to route the pipes underneath it instead of bring both to one side. good deal
lol
