header fitting
Old Dec 1, 2010 | 06:54 PM
410F-100's Avatar
410F-100
them flowtechs are also 3" collecters, so Youll be running dual 3" pipes... good luck trying to route that on your driverside!!!
oh and the added expense for the 3" exhaust system...
Old Dec 1, 2010 | 07:10 PM
NW 150's Avatar
NW 150
I'd just have them reduced down to 2.5", as of right now, that is the only set that ive found that says it will work, unless 2wd and 3/4 tons will work too?
Old Dec 1, 2010 | 07:24 PM
410F-100's Avatar
410F-100
ok soo
170 for the headers
+22 for bolth reducers
192
plus shipping
Or 200 for hookers plus shipping
Sorry Im just sayin...
Old Dec 1, 2010 | 08:18 PM
NW 150's Avatar
NW 150
If i can run 3" without clearance problems, then i wont care. But no matter what, i live 4 miles away from summit so nothing costs shipping for me
Old Dec 1, 2010 | 09:45 PM
HIO Silver's Avatar
HIO Silver
Originally Posted by NW 150
Oh, i looked that part number up on summit and it said in the notes for 3/4 and 1 tons only. so unless the number got messed up somewhere here, it's just another one of them parts that can work for more than what it's made for i guess.
get those pics up asap! lol
Here's the text straight outta Hedman's 08-09 Catalog:
4WD 1/2 & 3/4 ton pickup, F-150, F-250, F-350 (Light Duty Only)
Years: 65-76
Engines: 352-390
Headers:
Painted - PN 89120
HTC Coated - PN 89126
Elite or Stainless - PN 89830
Applications:
A/C - Yes
P/S - Yes
Transmissions:
Automatic Column Shift - Yes
Automatic Floor Shift - Yes
Standard Column Shift - Yes
Standard Floor Shift - Yes
Footnotes: 4, 6, 138, 166 (3/4 - 1 ton only)
4 = Includes parts necessary to retain emission devices (50-state)
6 = Modify stock exhaust to retain catalytic converter
138 = Will not fit Camper Special or vehicles with front sway bar
166 = Will not fit multi-shock absorbers, factory or aftermarket installations.
Emissions: C, G
C= For vehicles 1964 through 1974 without A.I.R. systems, considered as O.E.M. replacement parts when existing emission controls are not removed from vehicle.
G= 1975-1976 only, 50-state legal for these years only.
_____
I double-checked my rig and the collectors point directly to the center of the crossmember at a slight downwards angle. I had to cut the adapter tube at an angle to level the crosstube under the tranny ... plus provided another inch of clearance. I have radius drop-down brackets on my rig so be mindful of that in this pic:
I went to the shooting range and saw this rig in the parking lot.. It's a 66 F250 with duals going over the crossmember and exiting out the back.. and I mean the back! Looks like the dude relies on the cab tank
Tail pipes
At X member
View Undercarriage to rear. Didn't get a pic of the tubing going over the crossmember but you can tell by its proximity to the T-case that it is close.
Last edited by HIO Silver; Dec 1, 2010 at 09:50 PM. Reason: Revised the last image cuz I got the wrong IMG link.
Old Dec 2, 2010 | 08:37 AM
NW 150's Avatar
NW 150
Yea so it looks like i might be left with going under the crossmember. It doesn't look like the drivers sides comes down nearly is low? or is it just in that picture that you cant see it?
Old Dec 2, 2010 | 09:12 AM
2506deer's Avatar
2506deer
Talking headers
Just got done putting a pair of Flowthech headers on my 77 F150 4X4 with a 400 M.... It is a darn tight fit ... I had to take the started of on the passenger side and lift the truck up some to get the header in then on the drivers side I had to remove the dip stick tube and the front drive shaft.. and the collectors come out below the cross member.... don't know if I like that as they are kind of low still working on the run outs straight back to the rear they are very specific on the applications and I see why after putting them in... had to do a little tweaking on my power steering line as it was against the header other then that it was a good fit and seem to be of good quality.... check Summit racing and Advanced Auto .. they had the best prices good luck
Old Dec 2, 2010 | 10:23 AM
NW 150's Avatar
NW 150
yea if i get anything it'd most likely be from summit because like in a previous post, i said i live about 4 miles away from summit lol.
if you could post any pics of them on that'd be great!
Old Dec 2, 2010 | 12:03 PM
HIO Silver's Avatar
HIO Silver
In my pic, the driver's side wasn't installed yet but the collectors are at the same level. See, the collector flanges go back rather far and I would have had to make a quick 90-degree vertical turn up and then another 90-degree vertical turn in order to aim the tube btwn the trans and left frame rail.
I also took a piece of 2.5-inch tube and placed it along the left frame rail and there wasn't enough room for me. Try it and see if it fits your comfort zone. The items in the way included the parking brake cable, a bracket on the NP435, the NP203, and fuel/brake lines. I wanted ample clearance if ever I needed to get in there hence my decision to route both tubes along the right frame rail.
On the 66 F250 above, the owner ran manifolds with 2.25-inch tubing and had the luxury of a muffler shop to make little bends to adjust the route. Me? I had the luxury of laying on my back, a chop saw, grinder, a level, and a welder.
4 miles from Summit? YOU DOG!!! I AM JEALOUS. Heck, if I lived that close to Summit I'd end up working there!!
Old Dec 2, 2010 | 01:02 PM
NW 150's Avatar
NW 150
Oh hell trust me i know. If it wasn't for classes during the day, i'd apply there. I consider it a privilege to live that close to it lol
And from what you said, you have the drop radius arm bracket on in the picture, so it looks to me like i would have the room to route the pipes underneath it instead of bring both to one side. good deal
Joostin
Nov 30, 2016 12:06 AM
jbontke
89
Jul 28, 2015 02:23 PM
mmb617
Jan 9, 2015 12:11 PM
HI DEF
Mar 5, 2014 10:32 AM
hoxiii
Jan 15, 2007 07:05 PM
