5.8 e4od to 5.8 c6
Old Nov 30, 2010 | 08:46 PM
tredizz52's Avatar
tredizz52
5.8 e4od to 5.8 c6
hello i have a 92 f150 4x4 ext cab long bed 351w w/e4od 285,000miles, i found a 1993 f250 4x4 reg cab long bed rolling chassis no body with a strong running 351w and a rebuilt c6 wiring and computer for $475 how hard would it be to swap the 92 motor and trans for the 93 motor and trans
what would i need ?
how hard would it be?
thank you for any advice
Old Dec 1, 2010 | 12:51 AM
Mudsport96's Avatar
Mudsport96
Is your truck not running well or just want to swap because of high miles? If it runs good id pick up the roller and just wait till yours dies. Motor swap is straight forward pull yours drop the other in and use all your old sensors. Trans will be trickier since the c6 is not as long as the e4od you will have to either have drive shafts made of swap the differentials so you can use the longer shafts. The front shaft MAY work but the rear won't. I may be wrong so anybody that knows for sure can fill in the gaps.
kevh481
Jul 5, 2016 03:22 AM
Dyland
Mar 19, 2016 07:53 PM
thethrill
Mar 18, 2016 09:02 AM
Toplait
Jul 2, 2015 11:20 AM
Jrock909
Aug 4, 2006 10:07 AM
