E4od
Old Feb 24, 2016 | 09:22 PM
Dyland's Avatar
Dyland
E4od
I have a 90 f150 with a 5.0 with e4od trans and was wondering if an e4od out of a 92 f150 with a 5.8 would bolt up
Old Feb 27, 2016 | 09:05 AM
Conanski's Avatar
Conanski
Yes it will. But before you go through the trouble of pulling it out what exactly is the problem you're having that you feel you need to change it?
Old Feb 29, 2016 | 10:01 PM
Dyland's Avatar
Dyland
Its slipping really bad jumps in and put of gear shifts early and has no where near the power it used to
Old Mar 1, 2016 | 10:20 AM
Kemicalburns's Avatar
Kemicalburns
have you pulled codes? attempted a trans fluid/filter change?
Is your overdrive button located on the dash or at the end of the shifter?
Old Mar 14, 2016 | 10:49 PM
Brianlee's Avatar
Brianlee
Mine has shifted real hard in all gears for a long time please help
Old Mar 18, 2016 | 12:24 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
Originally Posted by Brianlee
please help
We can't help you with what little information you've provided. Do some things like:
*Obtain DTCs from your truck if present
*Check the transmission fluid. If brown or dark, it's burnt and probably needs to be changed, along with the filter.
If there are no codes and the fluid is ok, I would imagine it needs to be dismantled and properly diagnosed. Not something a home mechanic is capable of, take it to a shop that specializes in transmissions.
Old Mar 19, 2016 | 07:53 PM
Conanski's Avatar
Conanski
Classic signs of an electronic control problem, pull codes and post all the details in the new thread you start in the '87-96 general page.
92 Red F150
Jul 9, 2010 09:46 PM
78f3504x4
Jun 20, 2008 09:45 AM
