Sponsored by: Real Truck
No low range on transfer case
Old Nov 30, 2010 | 06:42 PM
2manyFords's Avatar
2manyFords
4x4 High works but no low. I have e code p1876 and p1832. Test says to check the ESOF solenoid for 12 volts to center pin which I have. Then says to check for resistance of the solenoid. from the center pin to both outside pins and it should be 45-55 ohms. Both of mine are open. I installed manual hubs on it last year due to both being bad. Is this solenoid for low range?
2002 F250 7.3 4x4
Old Nov 30, 2010 | 06:48 PM
dchamberlain's Avatar
dchamberlain
The ESOF solenoid is no longer relevant. It is only responsible for locking the hubs.
The same mechanism (shift motor, relays, etc) that shift into and out of 4x4 are also responsible for shifting into 4low. So if 4x4 is working, 4low should also be.
Now, many people forget that you have to have the truck in Neutral and your foot on the brake before the 4WD control module will attempt to shift into Low. If you are already doing this, then you may have a problem with the Brake Pedal Position switch.
Old Nov 30, 2010 | 06:54 PM
2manyFords's Avatar
2manyFords
BOO shows that it is working on scanner. Wont come out of park with out hitting pedal. Switch shows working on scanner but does not shift to low or even. MLPL shows all gears when shifting. Replaced the motor on the transfer case and the GEM module. Nothing changed. Is this GEM plug in play or does it have to be programmed?
Old Nov 30, 2010 | 06:58 PM
dchamberlain
The GEM has to be programmed. At least I think it does. It does so many different things and is the same GEM regardless of the truck (2 doors, 4 doors, automatic, manual, etc, etc, etc.)
Old Nov 30, 2010 | 07:02 PM
2manyFords's Avatar
2manyFords
When I ordered the GEM they asked if it had ESOF. there were only 2 choices.
Old Nov 30, 2010 | 07:07 PM
dchamberlain
I'm not familiar enough with a 2002. I know at some point they replaced the GEM with various modules that did what it did. The VSM for Vehicle Security, the 4WD control module for 4x4, etc. I know it happened in the early 2000 time frame.
If you really have a GEM, then it is responsible for door locks, keyless entry, 4WD and some other things I don't recall. So I would assume it would have to be programmed with the options for all of those different combination's.
But then, like I said, I'm not familiar enough with a 2002.
Old Nov 30, 2010 | 07:13 PM
2manyFords's Avatar
2manyFords
OK, this module is located above the glove box. Some places call it a 4x4 module. Other places call it a GEM. IS the GEM there or on the Fuse box?
Old Nov 30, 2010 | 07:18 PM
dchamberlain
I seem to recall that the GEM was on or near the fuse box. The 4WD control module is behind the glove box.
Old Nov 30, 2010 | 08:10 PM
2manyFords's Avatar
2manyFords
Went into the GEM module again with scanner and found PID that indicates neutral. it says "notNtTRL all the time? I plugged a MLPL off another car on it and it doesnt change. I applied ground to the circuit and still no change. I guess I need to check the wiring from the MLPL to the GEM.
Old Dec 1, 2010 | 06:55 PM
2manyFords's Avatar
2manyFords
Help. If I ground the red and white wire coming between MLPL and the 4wd module it works fine but will shift to low at any time. What am I missing? I have continuity between MLPL and transfercase motor. I also have continuity between 4x4 module and MLPL. MLPL is new and good.
jschlaf
Aug 23, 2016 03:29 PM
Dave.M.SD
Modular V10 (6.8l)
Mar 23, 2015 05:48 PM
Saminy
1983 - 2012 Ranger & B-Series
Jun 10, 2012 08:43 PM
rchalmers3
20
Oct 21, 2010 02:45 PM
John TN
Dec 1, 2009 03:05 PM
