Humming/beep sound
Old Nov 29, 2010 | 10:10 PM
bmiller131's Avatar
bmiller131
Humming/beep sound
Has anyone heard a sound when unlocking doors or opening or closing doors? It sounds like a hum and a beep (i know, real technical). Is it some sort of solenoid firing? Just curious.
Old Nov 29, 2010 | 10:16 PM
sncbluegt's Avatar
sncbluegt
yes and best i can think of is the truck is priming the fuel pump..cuz thats about where the noise is coming from
Old Nov 29, 2010 | 10:20 PM
bmiller131's Avatar
bmiller131
Thought of that, but it seems odd to hear it more than once in a short span. I just went out to put something in the truck and I heard when I hit the unlock button and once again when I closed the door. Weird...
Old Nov 29, 2010 | 10:28 PM
11350KINGRANCH's Avatar
11350KINGRANCH
Mine does it as well. I figured it was the fuel pump as well.
Old Nov 30, 2010 | 06:01 AM
I-BEAM's Avatar
I-BEAM
Why would the fuel pump be running with the ignition key off??? Just opening the door with the remote should not cycle the fuel pump?????
I'm confused!!!!!
Old Nov 30, 2010 | 06:56 AM
tampacamper's Avatar
tampacamper
Could it be the DEF tamk priming. When you lock it clearing the lines so they dont freeze.
Don't No!! Just my two cent's
Old Nov 30, 2010 | 07:02 AM
EpicCowlick's Avatar
EpicCowlick
I have a similar sound that popped up right after the 10B17 flash. Some of us centered the sound inside the transmission, directly above the pan. If you want to confirm, just craw under the truck with your remote and listen as you unlock the doors. There's a second-long tone coming from inside the trans. Very clear. Perhaps it is a solenoid or valve body? Who knows, but it is a change from the way the truck came from the factory.
Is this similar?
YouTube - 2011 Super Duty Post 10B17 Tone
Old Nov 30, 2010 | 07:22 AM
Marauder92V's Avatar
Marauder92V
That is an interesting sound. If it weren't linked to the door opening, I would say it was a fuel pump priming.
Epic -- my goodness man, is there nothing you haven't recorded!
Old Nov 30, 2010 | 07:47 AM
EpicCowlick
Lol, it's just an easy way to communicate. Someone said if a picture is worth a thousand words, a video is worth a million.
I recorded that sound a couple of months ago right after I got the flash. At the time I thought it was linked to opening the door somehow but later found that you can cause the tone just by unlocking the doors. And it is inside the trans for sure. Never have gotten an explanation why it's part of the TCM code now and wasn't before. Still don't know exactly what it is but I know many, many other trucks do it.
Old Nov 30, 2010 | 08:46 AM
bmiller131's Avatar
bmiller131
Is this similar?
Yours sounds more like a pop. Mine is a softer sound with a beep at the beginning, again similar to a fuel pump priming but the timing isn't quite right. Maybe I'll try to capture it and post tonight. My truck came to me with the update installed so I don't know if that's what caused it.
Old Nov 30, 2010 | 09:27 AM
Marauder92V
That is interesting that it is coming from the tranny. I have driven a new Ford every year for the past 23 years (company cars) and the last few years I have seen some activity involving the tranny and a need to flash. Wonder if they uncovered something and the flash you had done is addressing it. My truck should be here in a couple of weeks. I will let you know if I hear it on a brand new one.
Old Nov 30, 2010 | 09:51 AM
EpicCowlick
The simplest way to observe the sound is to simply stand next to the passenger side door and press the unlock on the key fob. Listen closely and there is a clear one-second tone. If you get adventurous, craw under the truck and press your ear up to the transmission pan. From there you can discern two separate parts of the tone.
Old Nov 30, 2010 | 10:04 AM
Marauder92V
If you get adventurous, crawl under the truck and press your ear up to the transmission pan. From there you can discern two separate parts of the tone.
Crawl under the truck? My sales guy told me that at 6'4" I would have no problem walking under the truck!
Is there any chance the sound could be transmitting through the tranny and originates somewhere else? I haven't been inside a tranny in a while and I wouldn't have thought there would be a lot of electronics inside them. What gets me is the connection to the door... strange to say the least.
Old Nov 30, 2010 | 10:51 AM
720Deere's Avatar
720Deere
Since 2003 all shifting is handled by electronic solenoids. There are quite a few in these transmissions.
I equate the sound coming from mine to the backup buzzer on an electric golf cart but at a distance.
Old Nov 30, 2010 | 11:08 AM
EpicCowlick
It makes more sense when you think about this from a software perspective. The TCM is signaling something to actuate in anticipation of start-up. So if a door is opened, or the key fob is pressed, or any electrical input is received, the transmission stands up and reports for duty, so to speak.
You can also hear various valves moving a few seconds after the engine shuts down. The EGR valve actuates a good 20 seconds after shut-down likely because it's just a healthy thing to do for an EGR valve. It may prevent soot choking the valve. Regardless, these things don't happen by accident. Some engineer somewhere said it would be good to exercise an element of the drive train so the software engineers figured out a way to do that.
Here's a sample of the EGR valve actuating:
http://www.youtube.com/watch?v=ycp7WYPpJAo
