Humming/beep sound
If its coming from the Tranny I would have to say Im with Epic on this one....anticipation of startup and maybe the solenoids are doing a cycle to get prepared..kinda a warmup procedure....I'm not by my truck but I would say if this is a startup anticipation...it would most likely do it on remote startup as well.
Oh come on! Someone needs to do the ear-to-the-pan thing and back me up on this one.
That is where it is coming from.
It also makes the noise by itself one or two more times if you wait around long enough. Such as when I was installing my mud flaps, it would make the noise randomly as I was sitting on the ground.
It makes the same noise after you shut the door, sometimes it does it after the lights go out and sometimes before. I just did it twice and the first time after I shut the door the same sound was made after 12 seconds (before the lights went out). I went back out and did it again and it happened with 1 second of when the lights went out.
Most times I hear it the second time when the lights go out.
I did...I think I even posted a picture of the pan on your other topic.
I have a feeling this issue will never have a resolution. It is heading in the same direction as whether UFOs really exist. I can almost see the similarity in these questions: "Are UFOs real?", "Is there really sounds coming out of Epic's tranny". When I get my truck in a couple of weeks, it will be the first thing I do. Okay, second thing. Driving it for 100 miles will be the first
Wouldn't it be cool to use plasma instead of good ole ULSD to clean the DPF? Wait until I figure out how to accomplish that via electrostatic injection for additional helicity. Once we resolve the tilting turbation within the required confinement area, it should be piece of cake.
That will be a cool sound coming from under the truck.
bothersome
Feb 7, 2020 02:31 PM
Fordenthusiasts
Apr 23, 2011 10:19 AM
