engine info/help
Old Nov 29, 2010 | 04:14 PM
dogstar's Avatar
dogstar
Question engine info/help
i bought an engine from a guy in my college class who said it was rebuilt about 4 years ago but sat in his garage since the rebuild. i'm getting the college to put the motor in but it's missing the distributor. the man at the parts store asked if i need an one vac. or a dual vac., i don't know. i know its a '68 302 from a Fairlane/Torino. any info on this year of engine would help. also, in your opinion, would you rebuild a 351m or a 302 for for power and torque and which would be cheaper. need help asap!
Old Nov 29, 2010 | 11:51 PM
85e150's Avatar
85e150
You can get a distributor with an electronic set up through these guys:
Performance Distributors - High Performance and Racing Ignition Systems
Single or dual vacuum? Points maybe... beats me. You don't want points, you want to upgrade.
Rebuild a 351m or 302 for power or torque....
Forget the 351m, you need to convert that to a 400 and do a pretty good rebuild to make real power. A 302 can make power, but it will be at higher and higher revs the more you do to it. (same as most engines)
302 would be cheaper to work on and build up.
Old Nov 30, 2010 | 06:47 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Single vac is for vacuum advance, dual vacuum provides for retard funtion during starting. Not needed, though either one will fit. A 68 would have had points, but you could go with a Petronics replacement, an electronic setup, Ford Duraspark from say a 77 Bronco, etc. The one posted above is a nice setup. Your choice.
Old Nov 30, 2010 | 11:20 AM
dogstar's Avatar
dogstar
thanks for your help. the part guy asked if i need steel gears or iron gears, how do i find out which one i need.
Old Nov 30, 2010 | 03:33 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Cast iron gear. They went to steel with roller engines.
Old Dec 1, 2010 | 02:26 PM
dogstar's Avatar
dogstar
ok, i found out the motor that was in my truck is a 351w. i bought a 302 for my truck and in the process of getting the school to put it in. with the 351w, what would you do to it to make it have some power (500?) and the cheapest way. Stroke it, better heads, over bore...? what are your ideas if you had around $1,500.
Old Dec 3, 2010 | 09:33 PM
Conanski's Avatar
Conanski
Originally Posted by dogstar
with the 351w, what would you do to it to make it have some power (500?). Stroke it, better heads, over bore...?
Yes... meaning all of the above plus an intake, full exhaust system, and upgraded fuel system, and then you'll need a transmission and rear end to handle the power.
There is no cheap way to 500hp.
Forgetaboutit until you have about $10 G to spend.
Old Dec 4, 2010 | 04:18 PM
dogstar's Avatar
dogstar
i can get 400 hp for $2,000 right now.
Old Dec 13, 2010 | 04:08 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Getting one horsepower per cubic inch is relatively reasonable. Anything more gets progressively more expensive per horsepower and less dependable.
Old Dec 18, 2010 | 06:57 PM
Terpfords's Avatar
Terpfords
If that is an original '68 4v 302 motor, those are some good heads.
Motors are cheap! Every thing you need to survive at that power level is expensive!
Old Jan 5, 2011 | 01:01 AM
gazguzzler's Avatar
gazguzzler
The rods are the weak point. Get a good set of H or I beam rods. KB hyperutectic pistons work great if you use a zero gap top ring that is opened wide to accomidate the heat. Then the piston wont crack. A decent cam and RPM airgap intake. Either port your heads and use chevy sized valves, and really open up the exhaust port. Or Ebay a set of some aftermarket heads. 500 is possible if you do the assembly yourself. Don't forget to balance the whole deal. Just buy smart and don't over cam it.
BritonCaleb
Apr 7, 2013 06:21 PM
Idaho_truck
18
Mar 8, 2012 04:58 AM
44nneedit
18
Jan 22, 2012 02:48 PM
dogstar
16
Dec 1, 2010 06:35 PM
71ranchero500
20
Dec 6, 2003 12:04 PM
