Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Allison auto experience
Old Jul 31, 2013 | 12:07 PM
gandrimp's Avatar
gandrimp
"Its an auto just drive it" Ok that's out of the way.
What I have is an "96" F800 with the 8.3 cummins and the mt653 Allison.
The issue is power,, the trans makes its final shift at 45 mph when accelerating, when pulling a hill it wont downshift out of 5th til 35 mph.
My last truck was an "05" duramax with the Allison and it basicly shifted like a car,,, I'm not expecting that type of performance, but I think it should downshift around 45 instead of 35 when pulling hard.
So for those of you with the Allison, how does yours shift.
Old Aug 3, 2013 | 11:02 AM
nevrenufhp's Avatar
nevrenufhp
You can adjust the kickdown, but factory setup is about like yours. I have been driving with them for a long while. You certainly can manually shift it when you hit a hill like that. The other option is to crank up the pump, and it wont bog down on the hills so bad.
Old Aug 3, 2013 | 10:26 PM
gandrimp's Avatar
gandrimp
I was wanting to crank it up, but I was concerned with how much the Allison could safely stand. Finding info on this setup has been difficult .
What I know is its a 210 hp 8.3 cummins but I find no info on the torque output.
The transmission is a MT653 Allison and I have found nothing on the stock torque handling capabilities.
I have read the low buck article and understand the process to slide the plate forward, but before I do that, how much will my Allison stand? How much heat will I build in the exhaust? How much actual power will this gain?
Old Aug 3, 2013 | 11:22 PM
nevrenufhp's Avatar
nevrenufhp
The 653 is rated at 250hp/850tq, but thats at 80k pounds. It will take much more, I assure you. A 210hp 6CT is roughly 650tq. Sliding the plate will get it to about 280/875. Added EGT is hard to guess due to many factors(engine condition, exhaust size and muffler setup, intake restrictions). You can get away with it on an empty truck in city driving, but you must have a pyro when loaded or any hills.
Then again, adding marine injectors and a bigger turbo will make a crazy 500hp monster out of it....but thats for manual transmissions only.
Old Aug 4, 2013 | 09:36 PM
gandrimp's Avatar
gandrimp
Well I'll need a pyro then. This is my truck that is used to haul equipment and we have lots of hills.
Thanks for the numbers you posted, that's a little less than what I was guessing for the stock setting.
Old Aug 5, 2013 | 08:45 PM
nevrenufhp's Avatar
nevrenufhp
Now you know you need to remedy the low number.
Old Aug 27, 2013 | 10:02 PM
Mike Hohnstein's Avatar
Mike Hohnstein
One thing you DON'T want to do w/a 653 is full power up shifts from 1st to 2nd. 1st is a creeper gear for off road and real slow going, has a auxillary planet assembly bolted to the back of the case.
Dr Matt
Jul 23, 2018 09:43 PM
TrickStyle3L
Aerostar
Oct 19, 2005 09:04 AM
351coupe
Aug 27, 2005 01:16 PM
MW95F250
Oct 7, 2004 11:17 AM
ray
Nov 7, 2002 02:17 AM
