F1 door alignment
Old Nov 28, 2010 | 11:16 AM
zeke51's Avatar
zeke51
F1 door alignment
Is there any way to adjust the door gap on an F1 cab?
Old Nov 28, 2010 | 11:30 AM
Julies Cool F1's Avatar
Julies Cool F1
Yes, with a big rubber hammer and a baseball bat!
If you have a Shop Manual, the procedure is described starting on page 295 (unsupplimented).
Old Nov 28, 2010 | 02:25 PM
zeke51's Avatar
zeke51
guess I gotta dig up a shop manual! Thx J
Old Nov 28, 2010 | 04:26 PM
Mervy49's Avatar
Mervy49
There are door adjustment spacers (shims)available at various aftermarket venders for this very application. They come in many widths (thickness). Place the appropriate ones through a trial and error method behind the upper and lower hinges. You can get a perfect gap all around your door, it just takes patience but can be done. Remember to put the spacer or spacers between the hinges and the door frame. It almost requires three hands.
Old Nov 28, 2010 | 07:41 PM
zeke51's Avatar
zeke51
mervy my problem is the gap is too big at the bottom. The shims seem like they would work if the gap was too tight. Am I missing something? Are the hinge half in the door removable and adjustable. Thx for your help.
Old Nov 28, 2010 | 10:11 PM
Mervy49's Avatar
Mervy49
Do you mean the gap btween the door and the rocker panel?
Old Nov 29, 2010 | 06:27 AM
zeke51's Avatar
zeke51
the gap between cowl and door at the bottom hinge.
Old Nov 29, 2010 | 07:34 AM
mtflat's Avatar
mtflat
The shop manual says to use fiber blocks to adjust by closing the door with the block in the hinge that needs to move. I read that as being a 2x4.
The manual also refers to cutting the tack welds that hold the hinges in place if smaller shims are needed.
I know the earlier car/truck manuals specified using a 2x4 and basically forcing things to move as necessary to achieve the results you want.
If you want to reduce the gap at the hinge/bottom either spread the hinge at the top to equalize the gap OR carefully use the 2x4 on the latch side of the door at the bottom and press the door toward the hinge.
Old Nov 29, 2010 | 07:56 AM
Lakotas53's Avatar
Lakotas53
You know this practice is still done today. I work in the paint dept. of an automotive company and when I walk across the catwalk to leave or go to lunch I can see associates down on the door line "tweaking" the doors by using a big rubber hammer and plastic wedges! Sometimes they even grab the door at the top and pull it outward to get just the right fit.........
Old Nov 29, 2010 | 08:42 AM
bobj49f2's Avatar
bobj49f2
Shims aren't really much of a help when it comes to adjusting these doors. I found the 2X4 way is about the only way. Also, the cab I have on my F-2 is from a very low mileage fire truck, 3000 miles, and the door openings were out of square on both sides. The top front and bottom rear corners had very little gap while the upper rears and lower front were too wide. I used a small port-a-power to push the corners apart and square up the openings.
Old Nov 29, 2010 | 01:41 PM
Julies Cool F1
There's the big rubber hammer and baseball bat (ok 2x4)
And you thought I was kidding, huh?
Old Nov 29, 2010 | 06:59 PM
Mervy49's Avatar
Mervy49
Truly amazing, the amount of information one can glean from here.
Old Nov 29, 2010 | 07:48 PM
59JEEPSTANG's Avatar
59JEEPSTANG
Years ago I had a door that was somehow bent in at the top, thought I was going to have to scrap an otherwise perfect door. Friend of my fathers came by (was plant manager for Ford for years) and he said to "adjust" it like we do at the factory. We put a 2 X 4 thru the window opening and yanked it a couple times and all was good again...
Paul
Old Dec 1, 2010 | 02:17 AM
19fiftyf3's Avatar
19fiftyf3
worked at a body shop in high school old man taught me to use sockets as well as 2x4's nice thing about sockets is that they are different lengths always worked for me good luck lots of good info on this site
Old Dec 5, 2010 | 07:04 PM
zeke51's Avatar
zeke51
excellent info from all of you who helped. BFH wins again!
52 Ford F1
WTB - Parts & other
Jun 19, 2017 05:25 PM
1948 F1dude
WTB - Parts & other
Apr 28, 2017 06:44 PM
AZAV8
Ford Truck Parts for Sale
Feb 3, 2016 12:33 PM
moejr
Jan 10, 2016 02:00 PM
Selfhl1
Oct 28, 2015 06:32 PM
