Carb heat
Old Nov 28, 2010 | 10:16 AM
parr4's Avatar
parr4
Carb heat
I've seen some different versions of adapter to plumb heated water into intake manifold. Versions of the adapter were metal. I'm wondering if phenolic plastic would also work? I know that stuff is used on other intakes, so I'm thinkin'.......? Inquiring minds n' such.
Old Nov 28, 2010 | 11:17 AM
Derrick lane's Avatar
Derrick lane
Heated water into intake manifold ? . Is this for cold start issues ?. I'm in the middel of installing a manual choke on mine. Never heard of heated water to the intake.
Old Nov 28, 2010 | 11:30 AM
parr4's Avatar
parr4
replacing OE exhaust manifold with efi type. OE has heated air to intake and efi type doesn't.
Old Nov 28, 2010 | 03:01 PM
AbandonedBronco's Avatar
AbandonedBronco
I would think that if you can put phenolic on top of the intake for a carb spacer, it should be able to go on the bottom. The only difference would be physical contact with coolant, but I can't see that being an issue.
Old Nov 28, 2010 | 03:50 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
It would need to be thick enough that you can torque it up for a water-tight seal. It would be pretty close to the exhaust, not sure how it could handle the heat.
Old Nov 28, 2010 | 04:38 PM
parr4's Avatar
parr4
I'm not ready to change manifolds just yet so I'm unsure of space measurement between rear manifold and adapter. Maybe AB can help with that. Phenolic plastic is fire resistant and heat resistant(up to a point). I'm thinking thickness would have to be ½"/more.
Old Nov 28, 2010 | 04:48 PM
AbandonedBronco
I'm not able to measure anymore, since I don't have the old manifold, but the picture shows there's a pretty reasonable distance between the exhaust manifolds and the plate.
Makes sense that it'd have to be thick enough to not break under the torque necessary to seal it.
Old Nov 28, 2010 | 05:05 PM
parr4's Avatar
parr4
AB....you don't have the vehicle in photo anymore? That pic shows rear manifold and adapter.....that is the measurement I was meaning. Hard to tell from pic but looks like maybe 2" or more....
Old Nov 28, 2010 | 05:08 PM
AbandonedBronco
I do, but I've since replaced the log intake with an Offenhauser 4bbl. I bought it used and the previous owner found some bizarre reason to weld the underside closed. Had to find a different means of heating it after that. Makes the setup completely different. =/
Old Nov 28, 2010 | 05:52 PM
parr4's Avatar
parr4
oic...k I'll cross that bridge measurement when I come to it. I'm thinking I want to keep the OE intake but modify it to accept a 2bb carb. I can find an old intake for $20 or so for testing at the machine shop and see what can be done as far as opening the throat up some, but for now all is speculation. Don't want offy/clifford intake. Thanks
coolguy1419
Dec 13, 2009 04:43 PM
mauicruza
1966 - 1977 Early Broncos
Feb 23, 2007 05:50 AM
tangcoral2004
Sep 10, 2004 10:21 PM
sbishop
19
Jan 15, 2004 08:30 PM
coloradov10
Mar 28, 2001 05:09 AM
