Diesel leaking
Old Nov 27, 2010 | 09:09 PM
gordeaux's Avatar
gordeaux
Diesel leaking
I'm leaking diesel!!! I have a 2002 F-250 with a 7.3 Power Stroke. Its puddling on the manifold and leaking to the ground. The smell is pretty strong. Someone suggested it was the o-rings on the fuel bowl draincock. I asked about this awhile ago, but the problem stopped, so I forgot about it. Since it started getting cold, the leak is back, maybe worse. Does anyone have a clue what I'm talking about? Can you guys give me some info. Thanks in advance!
Gordeaux
Old Nov 27, 2010 | 09:12 PM
clane's Avatar
clane
its the drain valve on the back of the fuel filter with yellow lever
Old Nov 27, 2010 | 09:19 PM
Kajtek1's Avatar
Kajtek1
Per my experience 10-years mark is pretty common when lot of seals and orings are giving up.
I replaced drain valve orings this spring, now I have oil cooler orings to replace. The front seals seems to get wet as well.
So stash some money, since those things are not cheap even DIY.
Old Dec 4, 2010 | 07:40 PM
MARCUSO's Avatar
MARCUSO
The fix
You have to get some special o-rings for the yellow drain lever. Seemed to only leak in cold weather for me.
They are Viton 202 o-rings. They are not available in small quantities, you probably have to order a bunch.
I went to a local viton distributor (google one for your region) and bought 6 for something like 5 bucks. They couldn't sell them to me, but they accepted a donation to their charity fund.
Repair is super easy, just drain fuel bowl, remove small bolts, and replace.
you might have some luck getting them here. Ford will RAPE you if you go to them for a valve assembly.
Good luck
Old Dec 4, 2010 | 07:57 PM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
You can order the parts from Replacement O-rings for Ford Diesel Engines on THIS PAGE. it'll take about 20 minutes or so to swap them out, depending upon how big your hands are...
For questions like this you'd be better off posting in the '99-'03 7.3 diesel forum.
Old Dec 15, 2010 | 05:06 PM
gordeaux's Avatar
gordeaux
Well, I replaced the o-rings for the fuel bowl drain, and I still am getting a diesel leak. Its not the drain **** leaking, I checked. Any experts out there that can give me an idea of where to look next?
Thanks in advance,
Gordeaux
Old Dec 15, 2010 | 08:09 PM
Kajtek1's Avatar
Kajtek1
Wash the engine and than line up the valley and all suspicious areas with paper towels. Start the engine and observe for wet marks on the towels. If none -take the truck for short drive and keep on checking.
Old Dec 15, 2010 | 08:19 PM
powerstroke72's Avatar
powerstroke72
Moved to 1999 - 2003 7.3L Power Stroke Diesel forum.
Old Dec 15, 2010 | 08:25 PM
timmyboy76's Avatar
timmyboy76
another possible leak, can be the 2-fuel rail lines that run on the inside of the valley, on the passenger side block. The "hold down" clamp, has a decency of rubbing a hole into the hardline.
Old Dec 15, 2010 | 11:29 PM
sand1's Avatar
sand1
make sure it not your filter sometimes they leak and cant even see it with your eyes until it starts running down the block
gordeaux
Nov 24, 2011 08:01 PM
gordeaux
May 27, 2011 08:19 PM
gordeaux
Jun 14, 2009 07:36 AM
gordeaux
Aug 20, 2007 12:16 PM
gordeaux
15
Jun 17, 2007 08:06 PM
