copper washer stuck
Old Nov 27, 2010 | 01:11 PM
1bigjoe's Avatar
1bigjoe
copper washer stuck
in injector closest to the fire wall , driverside ,,,,the copper washer won't come out, the injector was bubbling , so ipulled the injector to inspect (black carbon )but the washer stayed in the hole ,i tryed some grease on the end of a screwdriver , then just the screwdriver ,then the grab wire tool(thingy)
then i took thr hot wire off the ip and turned the motor try to blow it out ,that didn't work ,, what does anybody think i should do next
by the way its smoking way to much .blueish fuel- smoke
so what i did was repace the injector , not anew one just an other one
the timeing mark on the ip is just to the passenger side of the mark on the motor ,but i don't trust that because i know the oil fill cover was off at some point that was before i found this site
Old Nov 27, 2010 | 06:10 PM
ford390gashog's Avatar
ford390gashog
The way I get them out is using a long lag bolt with coarse threads and just twist it in and pull up very easy to do.
Old Nov 28, 2010 | 02:49 AM
Sycostang67's Avatar
Sycostang67
A hook tool set is what I use.
Old Nov 28, 2010 | 08:02 AM
1bigjoe's Avatar
1bigjoe
thanks -----lag bolt---ummmmmmmm-i just saw one
Old Nov 28, 2010 | 10:19 AM
fellro86's Avatar
fellro86
I use a pick, or as mentioned, hook tool.
Old Apr 25, 2016 | 08:03 AM
dtgl90vt's Avatar
dtgl90vt
I haven't tried the lag bolt yet, but I have tried a pick and spraying carb cleaner and freeze off to loosen the carbon and it doesn't move at all.
The reason I am posting though is because I don't know if mine is different, but it seems as if the center of the washer is set in some sort of collar. in other words it is perfectly recessed in a way that I can't get underneath it with anything.
Does this sound at all normal?
Thanks Again,
Devin
Old Apr 25, 2016 | 03:51 PM
Blanketr's Avatar
Blanketr
I just used the bolt that holds the air filter housing on. Twist in till you get a good bite, and pull up.. course, it will be junk afterwards...(the copper washer)
Old Apr 25, 2016 | 07:54 PM
Macrobb's Avatar
Macrobb
I've used a drillbit(much larger than the inside of the washer). Just give it a couple of whacks with a hammer to start it in the soft copper, then twist.
Old Apr 25, 2016 | 09:06 PM
dtgl90vt's Avatar
dtgl90vt
I went with a 1/4-20 bolt, I had to tug pretty good though with the vice grips though, it was in there good.
Macrobb
32
Aug 17, 2021 09:30 AM
OFD2413
17
Jul 26, 2019 01:13 PM
Phoenix02
Sep 11, 2017 12:48 AM
McBusiness11
Feb 13, 2017 04:10 PM
Tideman
Nov 22, 2016 06:55 PM
