Injector copper washer
Old Nov 16, 2016 | 06:55 PM
Tideman's Avatar
Tideman
Did my copper washer separate. If it did suggestions for getting it out.
Old Nov 16, 2016 | 07:00 PM
WatsonR's Avatar
WatsonR
Most likely, there are two of them. One on the injector, the other stuck in the bore.
Old Nov 16, 2016 | 07:04 PM
Tideman's Avatar
Tideman
Haven't thought about that. Already sent core back and was fooling around with my camera and just saw pictures tonight. Now I seen the inside lip. That answers ALOT of questions.
Old Nov 16, 2016 | 07:09 PM
Tideman's Avatar
Tideman
Bought truck with low compression on #8 cylinder. Never checked it myself. ForScan gave 2 codes that cylinder. Contribution/ balance and Misfire. Thought I would give it a shot replacing injector before going deeper.
Thanks Randy.
Old Nov 16, 2016 | 10:26 PM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
See? Like I mentioned to you, now fish that ring out of there, slap a new injector in and you'll be good to go again!
Old Nov 17, 2016 | 01:32 AM
Yahiko's Avatar
Yahiko
Clean the bore well,
Two very good tools for cleaning the bore. Add to that one compressor
to blow the bore out and the hold down bolt hole.
Sean
6.0L Tech Folder
Old Nov 17, 2016 | 07:33 AM
Tideman's Avatar
Tideman
T.D. how could I ever doubt you buddy.
Old Nov 17, 2016 | 07:37 AM
Tideman's Avatar
Tideman
Sean, did you pick up those brushes local or order them?
Old Nov 17, 2016 | 10:02 AM
bobv60's Avatar
bobv60
I found some brushes at Harbor Freight that worked good. A block cleaner set with nylon, brass and SS brushes.
http://www.harborfreight.com/engine-...-pc-69020.html
Old Nov 17, 2016 | 10:06 AM
Tideman's Avatar
Tideman
Thanks Bob I'll head there this morning. Got a lot of running around to do. Think I'll buy their compression tester while there. Something I should have done to start with.
Old Nov 17, 2016 | 10:52 AM
bobv60's Avatar
bobv60
Don't go too deep with the smaller ones. I had one small one come off of the holder. I was able to reach it with some long needle nose plyers.
Old Nov 17, 2016 | 03:52 PM
Yahiko's Avatar
Yahiko
I ordered them.
Sean
6.0L Tech Folder
Old Nov 17, 2016 | 07:05 PM
FiznUKa's Avatar
FiznUKa
I used that same set the last time I did my injector orings and they worked for the cup sides but the copper washer surface was an issue. You will need to find another brush like Yahiko posted.
Old Nov 17, 2016 | 07:18 PM
Tideman's Avatar
Tideman
Sean, I found one similar to yours but smaller. Do you remember where you got yours?
Old Nov 17, 2016 | 09:07 PM
BLADE35's Avatar
BLADE35
hows this Battle going
Are you going to replace the inject holddown too?
