New Batteries & Cables
Old Nov 27, 2010 | 12:46 PM
WarOzz's Avatar
WarOzz
Smile New Batteries & Cables
Just installed a brand new pair of Interstate Mega Tron Plus batteries and all new battery cables. Truck sat out in the snowstorm overnight with no block heater and fired right up at 30 degrees this morning. I never heard my truck spin over so fast.
Old Nov 27, 2010 | 01:35 PM
bubblegum's Avatar
bubblegum
What brand are these battery cables? Also how much do they cost? Also your left battery is rotated 180 degrees off, the positive terminal should be closer to the radiator and the negative closer to the fender (at least this is how mine sit).
Old Nov 27, 2010 | 02:05 PM
WarOzz's Avatar
WarOzz
Believe it or not I went with cheap set and was very pleased with what I got. They are super starts from orielys, $80 for the positive and $14 a piece for the negative. My theory on this was better a set of $120 cables then no cables at all while I wait to buy the custom set for $280. I also replaced both battery hold downs as mine were missing and the shock from a battery bouncing around can do damage.
Old Nov 27, 2010 | 03:17 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
War,what size cables are those?
stock was 2/0 and sometime pre-late 80's 3/0 was stock going down to the starter.
anything under 2/0 and your going to heat things up like a Christmas tree.
you don't want to burn your truck down.
i payed over $300 for these tinned marine 3/0 +/- cables.there was a good reason for it.
Old Nov 27, 2010 | 03:33 PM
WarOzz's Avatar
WarOzz
They are 2/0 same as stock. I wanted to go with the bigger custom cables but it just wasn't in the cards with having to buy 2 new batteries and all the other small things I am doing to my truck.
Old Nov 27, 2010 | 03:35 PM
FORDF250HDXLT
oh they are 2/0.ok all good!
nice deal.
make sure your buckled up before starting your truck now with nice new cables,cus she might spin and flip right over on ya.
Old Nov 27, 2010 | 03:40 PM
Coalroller's Avatar
Coalroller
War what are the cca? and ca? there is a place right across the road from work that sells the interstate and thats actually what i have in there now (8 years old) bout do or over do lol
Old Nov 27, 2010 | 03:50 PM
WarOzz's Avatar
WarOzz
It sure does turn fast now! Started in about 5 to 10 seconds this morning. I hope to improve on that. I have a new return line kit on the way to install next weekend and viton o rings for it already in my toolbox. I have a very slight air intrusion problem and it's getting fixed before it becomes a big problem
Old Nov 27, 2010 | 03:52 PM
WarOzz's Avatar
WarOzz
880 CCA - 1000 CA with an 85 month warranty!!!
Old Nov 27, 2010 | 05:31 PM
Coalroller's Avatar
Coalroller
sounds good... thanks man, wow gettin alotta help from you today! i owe ya
Old Nov 27, 2010 | 07:37 PM
bubblegum's Avatar
bubblegum
I looked up cables for my '91 and all I could find were 2/0 cables - which model years have the cables with the 3/0 starter section?
Old Nov 27, 2010 | 08:36 PM
FORDF250HDXLT
im not sure exactly.early/mid 80's with the 6.9's for sure.
Old Nov 27, 2010 | 09:38 PM
bubblegum's Avatar
bubblegum
I looked up cables for 1983, 1984, 1985 and 1986 trucks with the 6.9 engine, and all I found was the straight 2/0 cables.
Old Nov 27, 2010 | 09:45 PM
FORDF250HDXLT
what are the lowest temps you see bubble?
larger than 2/0 isn't required.it's just nice to have a little less resistance when she's really cold out.
it's likely stepping up in more CCA's is more beneficial.though they kinda go well with each other too.
if you want to just buy 'em.these guys will make ya up the whole works:
Heavy Duty, Aftermarket, Custom Battery Cables for your Car, Truck or RV
hmm.their link on f250/350 no longer works.i'll be dang.well they used to make the whole cable kit up for ya right there,complete with option to add 3/0 down to the starter.
bummer.maybe you could contact 'em and see if they still do.
used to read about guys getting them from there all time on here.
Old Nov 27, 2010 | 10:43 PM
mudbob's Avatar
mudbob
I got a set from them earlier this year and am very satisfied with them.
