DTCs after injector change...
Old Nov 27, 2010 | 11:01 AM
ramsay's Avatar
ramsay
I just changed a couple of injectors in my 2005 Excursion. All back together now and I have a P2552 DTC as well as an abnormally long crank time(8-10 seconds). After it starts it sounds really smooth. I changed the Stand pipes and dummy plug while I had things all apart as well as the FICM/injector harness because of a bare wire issue. Any ideas? What causes P2552?
Old Nov 27, 2010 | 11:59 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
P2552 = Throttle/fuel inhibit circuit
I have no idea what that means.
Old Nov 27, 2010 | 01:50 PM
bismic's Avatar
bismic
FICM or PCM open / short.
Old Nov 27, 2010 | 02:48 PM
ramsay's Avatar
ramsay
Originally Posted by bismic
FICM or PCM open short.
Which means?
Old Nov 27, 2010 | 03:07 PM
bismic's Avatar
bismic
Sorry for the brief response - Open circuit or short circuit - most likely in the FICM harness to the injectors IMO or maybe in the harness from the PCM. I suppose it could be an issue in the FICM itself, maybe a Tech would know that.
Old Nov 27, 2010 | 04:39 PM
cheezit's Avatar
cheezit
disconnect and reconnect the ficm. clear codes and retest. not a common code.
long starts after first replacing injectors is normal for a little bit do to air in the system
Old Nov 27, 2010 | 10:20 PM
ramsay's Avatar
ramsay
Thank-you cheezit and bismic. I dis- and re-connected the PCM to FICM harness, cleared the codes and it stayed gone.
mushman
Aug 13, 2012 05:51 AM
cmdevildog16
Jun 8, 2011 07:54 AM
derowe57
Dec 8, 2010 04:13 PM
gmhorse
Jan 7, 2010 01:15 AM
