New injectors???
Old Dec 7, 2010 | 01:10 PM
  #31
91dirtydiesel's Avatar
91dirtydiesel
would thread tape work or is that a bad idea
Old Dec 7, 2010 | 02:12 PM
  #32
snaponprofile's Avatar
snaponprofile
Tape won't help if its leaking from o-rings, and if it leaking from the injector it could be a worn out copper washer, or not torqued enough(the book says to do 35 ft/lbs, but I did 45ft/lbs, 5 is a bit too low and will likely leak).
Old Dec 7, 2010 | 02:26 PM
  #33
91dirtydiesel
The hard line attachment is leaking
Old Dec 7, 2010 | 03:36 PM
  #34
snaponprofile
Perhaps teflon might help, but I never had that problem. You ever put a wrench on there to see if its tight?
Old Dec 7, 2010 | 08:46 PM
  #35
91dirtydiesel
I've tried to reseat it and tighten it 3 times now
Old Dec 7, 2010 | 08:56 PM
  #36
snaponprofile
Is the flange on the injector line nice and rounded with no nics or gouges? Is the place where the injector line sits in nice and contoured for the injector line?
Old Dec 7, 2010 | 09:10 PM
  #37
91dirtydiesel
It takes a hard angle, the line isfelf. Can the return lines back up at all and leak out the top?
Old Dec 7, 2010 | 09:20 PM
  #38
snaponprofile
I'm not sure if the line can back up, I doubt it. Are you sure that the adapter if leaking and not the return line fitting right below? The o-rings on that injector could be leaking.
Old Dec 7, 2010 | 10:40 PM
  #39
91dirtydiesel
I took my IP out and lines (not injectors) and been leaking since maybe when I loosened lines it broke the injector loose?
clean concepts
Aug 2, 2012 07:02 PM
JHoffman93
Sep 18, 2011 02:30 PM
93turbo7.3
Dec 31, 2010 10:10 AM
Miner33
Nov 13, 2007 08:44 PM
cjlawther
New Member Introductions
Dec 26, 2006 08:48 PM
