New injectors???
Old Nov 29, 2010 | 02:27 PM
snaponprofile's Avatar
snaponprofile
Ok sounds good, and me too I guess once I get em and put the new ones in. I wanted to change them together too, but I don't think I will for the same reason as you.
Old Dec 3, 2010 | 03:20 PM
snaponprofile
Hey guys just got injectors and they sent me a 24 copper washers including ones on injectors. How many should I have per injector?? Only one right?
Old Dec 3, 2010 | 03:38 PM
snaponprofile
Also, do I have to torque the injectors and lines?? I don't have a deep socket that big, so can I just tighten them with a open ended wrench??
Old Dec 3, 2010 | 04:39 PM
farmert's Avatar
farmert
You only need one copper washer per injector. When I installed the new injectors in my 85, I just used a wrench, untill they were tight. It seems to run all right.
Old Dec 3, 2010 | 06:31 PM
snaponprofile
Thanks, did you remove all the lines or work around them? Because I'm working around the right now and doing fine.
Old Dec 3, 2010 | 07:41 PM
snaponprofile
Is it normal to see rust on injectors?
Old Dec 3, 2010 | 11:30 PM
farmert's Avatar
farmert
I removed the lines from one bank of injectors removed the return lines from that bank, removed and replaced the injectors on that side, installed new return lines and caps, tighted the injector lines, then moved to the other bank. I left the lines mounted to the pump, just carefull moved them to the side to get the injector out. Yes I had a little serface rust on the body of the injector, between the top threads and where the copper washer mounts. The copper washer seals the bottom, but a little moisture works it's way threw the top threads.
Old Dec 4, 2010 | 08:23 AM
snaponprofile
Ok, thanks. I saw pretty much the same thing. Started it up last night after injector swap and it sounds great! No leaks and I'm ready to put the banks on
NOTE: The return line kit from Pensacola Diesel isn't great at all and I don't recommend it. The return lines are blue, and I had to get extra fuel lines from Strauss auto.
Old Dec 6, 2010 | 06:56 AM
NorthernDiesel's Avatar
NorthernDiesel
I found the same with the Pensacola return lines. Not too impressed. I'm going for the metal fittings ASAP anyways, I'm not dealing with this leaky plastic BS any more.
Old Dec 6, 2010 | 01:59 PM
91dirtydiesel's Avatar
91dirtydiesel
on the injector #1 or #2 do you have a spacer on the front passenger side cylinder? its like a 2 inch adapter on top of that injector
Old Dec 6, 2010 | 02:20 PM
snaponprofile
Yes, I got that.
Old Dec 6, 2010 | 02:28 PM
91dirtydiesel
ok well im leaking really bad from there and also one of the return lines at the back driver side of motor.. im thinking of just getting the whole kit and injectors that you guys where just talking about
Old Dec 6, 2010 | 03:10 PM
  #28
snaponprofile
I got BB's from pensacola diesel-they are great!; just don't get their return line kit-it sucks.
Old Dec 6, 2010 | 03:25 PM
  #29
91dirtydiesel
Haha good to know! Any insight on y I'm leaking out the back?
Old Dec 6, 2010 | 07:57 PM
  #30
snaponprofile
Could be an o-ring or loose fitting. The way I fixed my leak was all new injectors, o-rings, and copper washers-no more leaks
