F150 4x4 problems
Old Nov 26, 2010 | 08:46 AM
AAV's Avatar
AAV
F150 4x4 problems
Have a 2004 F150. When turning on the 4x4 ( in nutral with the brake paddle down) 4x4 lights on the dash goes on but nothing happens don't feel anything clicking in. Sometimes the 4x4 low/hi lights on the dashboard don't go on at all. Is this a 4x4 switch. Can somebody give some advise on what to do. Thx for your time.
Old Nov 26, 2010 | 05:33 PM
Coskid's Avatar
Coskid
Trying moving just a bit. When you switch to 4hi you don't need to be in neutral this is only done for 4low. Sometimes you won't here it switch until you move a bit.
Old Nov 27, 2010 | 03:25 AM
DestinationFX4's Avatar
DestinationFX4
It could be the solenoid in the transfer case. try banging it with a rubber mallet in the back of it.
Old Nov 27, 2010 | 07:17 PM
Piratetech's Avatar
Piratetech
Likely the shifter motor is seized up. Its on the outside of the case, and tap it easily with a mallet. Then once it works, engage 4 hi at least twice a month and this will not happen again!
Old Nov 27, 2010 | 07:41 PM
Christofiso's Avatar
Christofiso
If it is the old style f150 you might have a front axle shift fork issue. The transfercase shift motor has a sensor that tells you that power is going to the front differential. On the front axle check to see if there is a vacuum motor on the right side of the 'axle tube', this was a common problem. the plastic sliders inside the on the locking collar of the splined axle shaft would wear out. If you have this vacuum motor on the front axle.... time to pull the front diff.
jsp_8701
Jul 1, 2014 06:12 PM
Mussifto
Dec 21, 2012 06:41 PM
4x4superduty88
1997 - 2003 F150
Nov 9, 2010 05:28 AM
dkillianjr
Jun 2, 2009 08:20 PM
minnesota4x4
Sep 10, 2007 11:15 AM
