Sponsored by: Auxito
2002 supercrew brake light problems
Old Nov 4, 2010 | 09:22 PM
4x4superduty88's Avatar
4x4superduty88
I have a 2002 f-150 supercrew 4x4 with 5.4 engine. The passenger rear blinker or brake light don't work. The light will burn with the headlights on but no blinker or brake light. The blinker blinks fast on the passenger side. I have replaced the multi-switch and have checked all the fuses. The wire connector under the bed isn't showing any current on brakes. Can someone tell me where else to look. THanks
Old Nov 4, 2010 | 09:38 PM
Bluegrass 7's Avatar
Bluegrass 7
The bulb is a dual filiment type.
The running lamp/park element does not blink, only the stop filiment blinks with the turn, 4 way and stop functions.
Have you changed the bulb ?
If all three other lamps blink on 4 way, it's not the turn signal switch.
The lamp is an open circuit that makes the flash rate speed up because the current drawn is to low to heat the flasher to the correct temperature for a normal flash rate.
Good luck.
Old Nov 6, 2010 | 10:08 AM
4x4superduty88
Yes I did change the bulb. I have no signal on 4 ways on that taillight. All the others work fine.I dont know if i need to change out the taillight holder. Could it be burnt and not working on brakes?
Old Nov 9, 2010 | 02:05 AM
vista461's Avatar
vista461
Had that on my 01 Supercrew, changed the bulb socket and that didn't help. There was a bad spot in the wire somewhere in the last couple feet on the taillight harnes for that taillight. Replaced the wire and has been working for the last year. Not sure how or why it went bad but it did. Couldn't see it from teh outside, needed to use a multimeter.
Old Nov 9, 2010 | 05:28 AM
n5926g's Avatar
n5926g
Pull the new lamp out,and take a good look inside the socket.I had a similar problem on my 97 XL,and found a "hot spot" on one of the contacts in the socket.Cleaned it out really good,and checked for continuity.Worked from then on.
Dozier4life
Dec 2, 2016 10:11 PM
tufftruck
Nov 10, 2016 12:54 PM
77_f250_custom
May 12, 2015 06:00 PM
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
duvaller
Electrical Systems/Wiring
May 18, 2014 07:54 PM
