Looking to get into a 05-07 F2/350 crew
So heres the short of it, lived in NYC for a couple years and just moved back to jersey and for short notice i picked up a cheap ranger to save money, as i am a rather big and tall man, 6'10 this situation needs to be fixed immediately, Just wondering what issues i will be dealing with, problems, quirks, major issues if any. This truck will not really be used for heavy work as its main purpose is driver comfort, thanks for any advice, info and or tips in advance!
I own a 05 F250. The main problems you would face with the 6.0 is the egr system and stud bolts. They make an EGR delete, but its for offroad use only.. As for the stud bolts, you should be ok if you dont install a programmer or push your truck to hard. They do make a stud bolt safe programmer from Spartan tho. Another problem encountered is the fact that most dont come in for the plug cord for the block heater. Living in NY, I would probably invest in one (simple fix). Overall tho, I rate the truck an A+ for power. Would be a great investment.
FordGiant, i would be very picky about what intake you put on a ps if you put one on at all. You don't want any particulate mucking up your turbo. Also... I don't know where you found a blow off valve for this truck, but it is probably a crock of s***! Diesel engines do not have throttle plates and BOVs let off pressure between the throttle plate and turbo. I guess there could be some use of a BOV due to engine pressure but i doubt you will see any gains from such an add on...
nnero
03-18-2009 01:40 PM
somairot
New York Chapter
02-25-2006 02:56 PM
somairot
02-23-2006 11:10 PM
