trailer brake controller
Old Aug 20, 2011 | 12:46 PM
mblaksley's Avatar
mblaksley
I found the grey plug under the dash - need help
I'm sure everyone has had about enough of TBC installations. I'm moving my tekonsha primus iq from my expedition to an 02 excursion. The picture below helped me locate the grey plug way up under the dash on the right hand side of the dash support. Great picture by the way...I have the brown ford plug that connects from the TBC, but cannot seem to maneuver around the grey plug to line it up so it will click in. What am I missing? I really need to save the money and do this myself. Are there other parts of the wiring I should disconnect to make it easier to make the turn under the dash so the brown will fit into the grey. Thanks ahead of time for any help.
Old Aug 23, 2011 | 06:31 AM
LOVEMYBIGFORD's Avatar
LOVEMYBIGFORD
It's not the most convenient place to access for sure.
If you are sure you have the correct connector, it will fit in there to line up.
Seems to me when I did mine, I barely got it started with my fingers then using a long screwdriver gently pushed it into place by using the metal dash hole as a pivot surface for the screwdriver.
Good luck.
Old Aug 24, 2011 | 06:32 PM
mblaksley's Avatar
mblaksley
Thanks...I finally got it. I worked and worked trying to plug it in and finally had to leave it for awhile. Came back and had it plugged in within 5 minutes. It's truly a two handed effort. One under that dash guiding the plug and one through the dash guiding it into the receptacle. Glad it's done. Not sure how I would get it out if I ever need to unplug it...but I'll worry about it then.
fordtrkpuller
Mar 15, 2021 06:35 PM
67xr7kat
All Things Towing
Feb 16, 2020 09:02 PM
Eric Ahl
All Things Towing
25
May 28, 2017 07:06 PM
Resendiz
Sep 22, 2016 10:45 PM
srb1194
2004 - 2008 F150
Jun 14, 2016 03:54 PM
