2011 E 350 OEM Trailer brake controller
Old Apr 15, 2016 | 10:02 PM
67xr7kat's Avatar
67xr7kat
I have a 2011 E-350, I'm looking to install the factory trailer brake controller. The connector for the controller is behind the dash, what else do I need besides the OEM controller ?
Thanks
Old Apr 15, 2016 | 11:56 PM
wrvond's Avatar
wrvond
Shouldn't be anything else required (other than fuses & relays). Keep in mind there are two parts to the controller that you need to make it work. If the price is low then they are likely only selling the controller section and not the relay pack that mounts above the knee shield area on the driver's side.
Old Feb 16, 2020 | 09:01 PM
HDryder05LH's Avatar
HDryder05LH
What relays are you referring to?
Old Feb 16, 2020 | 09:02 PM
HDryder05LH
Thanks
How did you make out with this?
rvpuller
Mar 16, 2013 06:59 AM
chaser1602
1997 - 2003 F150
Apr 4, 2012 09:09 AM
kell104
Jan 11, 2009 05:06 AM
FX4_FAN
All Things Towing
May 16, 2005 08:01 PM
