E4OD Problem
Old Dec 16, 2010 | 06:27 PM
danlee's Avatar
danlee
Originally Posted by Mark Kovalsky
Yes they do. It is either a complete loss of power to the trans or a missing ground to the trans. My money is on the power to the trans.
Mark,
You win, but it was more than power to the trans. One of two connectors mounted on a bracket was disconnected. I think that it carries all the Solenoid control lines. i remated it and now the trans is shifting as it should.
Old Jan 18, 2011 | 07:47 PM
danlee's Avatar
danlee
My E4OD is in an '83 F100 with a carburated 302 motor. I use a '91 diesel ECM to control it. I have a MAP, VSS, RPM, and TPS sensors.
It shifts fine through 4 gears, but it will not kickdown when I floor it and go to WOT. The jeep TPS that I am using only gets to 2.0 Volts at WOT. The carb is a Carter 4 barrel, and closed to wide open throttle is about 90 degrees. The Jeep TPS needs more than 90 degrees rotation for full voltage.
What should the voltage be for the 'kickdown' on an EEC-IV ECM?
Da_Lariat_Chariot
Mar 20, 2018 08:25 PM
rustyandleaking
Dec 30, 2016 01:16 PM
clarkbre
Sep 4, 2014 07:37 AM
gyesko
Aug 16, 2013 06:20 PM
cptbarkey
Jan 15, 2011 10:46 AM
