Excursion Automatic to manual change
Old Jan 17, 2011 | 05:16 PM
Aleks Riga's Avatar
Aleks Riga
Hallo, Gentlemen !
Does someone has expierence in automatic 5-sp torqshift replacing by manual
ZF 650 in Ford Excursion 6,0 diesel?
Idea is to get all the staff from the donor vehicle - f-250 extended cab.
It's looks to fit, but maybe someone can point me narrow places in this process, some kind of electronics repining, or mechanical troubles. I'am from
Latvia (EU), it is rare truck in my land, so asking for help to Big American brother.
Old Jan 18, 2011 | 10:40 AM
Lazy K's Avatar
Lazy K
Are both trucks two wheel drive or four wheel drive? Is the donor F250 also a 6.0 Power Stroke?
Old Jan 18, 2011 | 02:39 PM
Aleks Riga's Avatar
Aleks Riga
Yes, both 4x4, both has 6.0 powerstroke, both has drives selector switch on the front panel.
Old Jan 19, 2011 | 10:53 AM
Lazy K's Avatar
Lazy K
https://www.ford-trucks.com/forums/7...nual-swap.html Click on this link and read it. Not the same as your swap but you may have the same floorpan issues.
You may run into driveshaft length issues as well but you could measure both to see.
The only other problem would be if the crankshaft in the auto trans engine is not machined for the manual trans pilot bearing.
Old Jan 19, 2011 | 02:56 PM
Aleks Riga's Avatar
Aleks Riga
Thanks a lot ! I will compare crankshaft serial numbers, they will be same or different.
