CAB BUSHINGS ?
Old Nov 23, 2010 | 08:30 AM
blk dog's Avatar
blk dog
CAB BUSHINGS ?
Really ! Nobody has any advice on replaceing the cab mount bushings ? 82-F-100-2wd.
Old Nov 23, 2010 | 12:19 PM
85_Blue's Avatar
85_Blue
I just replaced all my bushings about a month ago, and all four of the cab ones was a two person job. I actually had to cut the original ones out with a saw-zaw, careful not to ruin the bottom, cause you will re-use it.
I had to pull up the kick panels to get the carpet to come up to get access to the bolts for the front two. The back ds one was the worst since you either work around the fuel tank or drop it. Since I had my pal helping I had him tighten/loosen from the top. All the rest he held & I worked from the bottom.
Hope this helps ya.
Old Nov 23, 2010 | 02:21 PM
blk dog's Avatar
blk dog
Thank you 85 blue ! were you able to lift the cab by hand?
Old Nov 23, 2010 | 03:07 PM
85_Blue's Avatar
85_Blue
sure you can move it around a bit, but you really need a jack, especially when putting the new ones in place. I went back with poly and they were like flippin towers compared to 25 year old rubber!!!
Old Nov 24, 2010 | 05:52 AM
blk dog's Avatar
blk dog
Once again thanks 85-Blue.I will post back on my effort for anyone thats interested.Just discovered a more pressing problem.(beleave I have blown head gasket).
hickory1991
Jun 16, 2012 07:38 AM
1975Ford
Oct 31, 2006 04:30 PM
scorpiohunter
Mar 30, 2006 08:14 PM
Taynton1
Dec 9, 2004 09:42 PM
inliner
Jan 15, 2003 04:49 AM
