cheap lifts?
Old Dec 7, 2010 | 12:43 AM
  #91
TexasGuy001's Avatar
TexasGuy001
Originally Posted by 6CylBill
I agree. But I will say this; A suspension lift raises the center of gravity also, and more so at that. A body lift won't raise your center of gravity near as much.
I see it this way about the center of gravity though. The stock suspension has springs that are designed for the stock center of gravity. A suspension lift has springs that are designed for the changed center of gravity and are usually stiffer as well.
Old Dec 7, 2010 | 12:45 AM
  #92
TexasGuy001
Originally Posted by L. Ward
1987-1991 Ford F150 2wd & 4wd - 3" Body Lift Kit
Product Part #:
763
Product Brand:
Performance Accessories
Body Lift Kit Tech Notes:
5. It may be necessary to drill the front two body bushing sleeves out to 1/2" for new bolt clearance.
11. Vehicles equipped with 6 cyl or V-6 will require replacement of lower radiator hose to avoid contact with smog pump.
14. Will not fit vehicle equipped with diesel engine.
26. No bumper brackets are included
The problem you are going to run into is the way the frame horns extend into the bumper, you are pretty much going to have to make your own and notch the bottom of the bumper or the frame to let it raise up 3" or else accept that it is going to look like this
Now, since you evidently want to ignore those of use who have already been there/done that and ended up
And, since you seem determined try and throw on this
So you can put on these
Without addressing this
or this
or this
While trying to make a 185hp 302 with this
this
and this
power something like this
and seem to be determined to do this
May I suggest on the front and back frame rails mounting some of these
or these
Preferably like this
So when the stock 302 can't spin the tires enough to keep moving and ends up like this
Someone who actually geared and setup a truck correctly can hook up and do this
Oh, and when you end up stuck, DO NOT use one of these
Unless you want your hood or tailgate to look like this
Fantastic Post!
Old Dec 7, 2010 | 11:30 AM
  #93
6CylBill's Avatar
6CylBill
I love it! Amazing post! Give this man a cookie!!!!
VMPowerstroke
Nov 24, 2021 07:50 PM
CFarrell
Idaho Chapter
Sep 30, 2020 11:12 AM
MuddFord
Feb 22, 2014 03:07 PM
Lowboy44
Feb 24, 2012 08:50 PM
sdunham
Jul 18, 2003 03:12 PM
